Question about Cookshack SmartSmoker SM150
Error code tt69 on cookshack smoker - Cookshack SmartSmoker SM150
Why am I getting an EAA1 error after 5 minutes of first use?
I have the same model and drew this schematic after taking it apart to fix another problem. An EAA1 means that the control display unit is getting a bizarre reading from the temperature sensor on the box. Could be a connector problem or a faulty temp sensor. The temperature sensor has a long path through the relay power supply board in the bottom then up to the control display unit. Unfortunately the only place you can easily check is the 5 pin connector directly under the control display unit. Try reseating this connector. The box can be opened up to check everything else but it's a real bear.
Jun 23, 2014 | Masterbuilt 20070411 30" Electric Smoker...
Masterbuilt 20072612 ERR1 error code
ERR1 MEANS YOU NEED A NEW BODY KIT. PER MASTERBUILT, THE SMOKER IS DEAD AND NEEDS A FULL BODY KIT (BASICALLY THE ENTIRE UNIT)
Apr 18, 2014 | Masterbuilt 20070106 Electric Smoker
Masterbuilt ea2 error code
Same problem here. Any answers yet?
Jan 02, 2014 | Masterbuilt 20070106 Electric Smoker
Masterbuilt smoker model 20070910 with controller error code eaaf. email: pontoon5@windstream.net
Hi and welcome to FixYa, I am Kelly
It is telling you that the temp is below 40 degrees F. All you need to do is warm up the temp probe to 40F and it should work just fine. Use a hand held hair dryer or a warmed up shop vac on b.l.o.w to warm it up.
Happy New Year,
Kelly
Jan 01, 2011 | Masterbuilt 20070106 Electric Smoker
I am getting a EEAF fault code and the smoker will not heat. What is wrong?
To RESET control panel:
If control panel shows an error message, turn electric smoker off, unplug unit from outlet, wait
ten seconds, plug unit back into outlet, then turn electric smoker on. This will reset control panel.
ASSEMBLY, CARE & USE MANUAL
WARNING & SAFETY INFORMATION
MODELS 20070106, 20070206
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
I am getting the EAAF code. What does it mean?
The manual said to unplug the smoker and wait 10 secs and then plug it back in. I tried that and it did not solve the problem. However, I did leave it plugged in with that error code while I was searching the web for an answer. Over the next 5 min or so, the error code went away and my smoker started heating up as if it had no issues.
The solution may be to just let it sit for a few min and then it will begin on its own. The only variable I can think of is that I am smoking in cold conditions for the first time. It may be the case that since the smoker was outside in single digit temperatures, that may have triggered the error code. Who knows, in any case, I am back to smoking for Thanksgiving. Crisis averted.
I have a Cookshack smoker problem
Try running an extension cord from inside the house and running it for 2 hours. Then it should work on outside grounded outlets in garage and such. The elements get moisture when new and this drys them out.
Jan 12, 2010 | Cookshack SM009 Smoker
EAAF Error Code
I went to start my smoker Thanksgiving morning in Denver and I got the EAAF error. I checked all electrical connections and they appeared fine; I next removed the digital control box and stuck it inside my jacket to warm it up (was 15 deg outside) and lit a candle inside the smoker. After 20 min I put everything back together and it worked. Just remember to remove the candle inside the smoker. I plan to call Mastercraft on Monday to see if they can tell me what EAAF means.
Dec 13, 2009 | Masterbuilt 20070106 Electric Smoker
Cookshack SmartSmoker SM150 Logo
Top Cookshack Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Cookshack Grilling Expert? Answer questions, earn points and help others
