Question about U.S. Robotics (USR5450) 802.11g/b Wireless Access Point
How to create a port on my router
I have USRobotics 9115 ADSL router.
can you tell me how to create a port on my router.
thanks.
  • 31 Answers
Please follow the steps are given below,
1.Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
2.Type your username & password and login to device.
3.A web page will appear , you can go to security section & select virtual servers.
4.From virtual servers section you can create port you want either TCP or UDP.
best regards,
Krishan
Posted on May 09, 2009
  • 413 Answers
Had the same prob with my linksys and xp. But there is a way to open a port to allow users to join your server. I went to my linksys congifuration page at 192.168.1.1 in my web browser, advanced, fowarding, set service range from 2709 - 27106: make the protocool both if you can otherwise udp. I can make a counter strike server by forcing the port thourgh 27105 and runs fine
  • shankar anand jha
    shankar anand jha May 09, 2009
    i think same info is delivered everwhere
I want to install ADSL2/2 + modem with 4 port ethernet router, along with Xtreme N dual band gigabit router. My OS is Windows 7. I tried to inserting the IP address but this had no effect. Do I need new...
Hello there,
When you ask questions, you have to tell the exact model. When you say you want to install it, do you mean configure the ADSL connection and Wireless LAN? If so, you have to configure the ADSL connection first. You have to get the settings from your ISP. Usually the default address for D-Link routers is 192.168.0.1. You would also want to check the user manual.
You do not need the drivers. You are going to connect it via ethernet cable. And then you can configure from there. Once ADSL connection is working, you can now connect your Gigabit router to one of the ports on your ADSL 2+ gateway.
Feb 22, 2011 | D-Link Computers & Internet
I have a U.S. Robotics USRobotics USR5461 Wireless router
heres the online installation manual http://www.usr.com/support/5461/5461-ug/index.html
see configuration tab - You will not be prompted to login the first time you connect to the Web User Interface during the initial setup. During the Setup Wizard procedure, you will be prompted to create a user name and password to log on to the router. If you create a user name and password, you will need to use these whenever you want to log on to the Wireless MAXg Router. The user name and password are case-sensitive.
------------- so if you cannot remember the username and password - you will need to reset to fsactory condition and reset all the settings in the router for it to work with your ISP again
the reset button is on the back - RESET Button: To restore the factory default settings, use a paperclip to press in and hold the RESET button for five to ten seconds. If the RESET button is pressed for less than five seconds, the Wireless MAXg Router will reboot.
Apr 24, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
Tell me about good adsl router
here some of best ADSL routers,
Linksys
Belkin
USrobotics
Prolink
regards
Krishan
May 11, 2009 | Computers & Internet
Very low signal (wireless maxg adsl gateway usr9108)
Have you tried changing the channel? This might help icrease your signal aslo avoid putting it near wall and if possible put somewhere higher (5-10 ft above the ground)
May 01, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
Router can't be accessed from the WAN
I had the same problem with Firefox 3.0, try using IE
Jan 22, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Wireless
What are you trying to connect to?
Jul 04, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
LinkSYS ADSL2 -AG241Modem + Router Ethernet
First : check your cables if its plugged in securely on each each
port
Second: Try to change their ends
Third : Try to replace your Ethernet cable.
If your router is connected to a modem try to isolate the problem by connecting your router directly to your computer and check f light would turn on. IF YES then thers something wrong with your modem, check it out.
Hope those simple steps ive provided helped you in way, If not pls let me know and lets keep the ball rolling.
Cheers.
Jun 19, 2008 | Linksys ADSL Modem + Router With 4-Port...
Not able to Login to us robotics 9108 adsl modem
Try admin for the username with a blank password.
Chris
May 29, 2008 | D-Link AirPlus DI-614+ Wireless Router
U.S. Robotics (USR5450) 802.11g/b Wireless Access Point Logo
1,018 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Prashant M
Prashant M
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
