Question about Timex T600 Clock Radio
Indiglo light burnt out. can it be replaced - Timex T600 Clock Radio
Might light no longer works, had battery checked and it is fully charged. Please advise
the indiglo of your watch is probably busted, you had to replaced its dial. the the battery has been checked but not the watch by a new battery? try to check the watch by a new battery. if still not lighten up check the connection of the button it probably cannot connect the connections of the light. i hope this advise will help you a lot.
Sep 08, 2011 | Timex 2D421 Stainless Steel Perpetual...
The light quit working.
One of two things could be causing the issue. If you have used your Indiglo a lot then the light source has burnt out. The other possibility is that the micro switch inside the case that turns the light on and off has broken. The only way to find out which is the cause is to take the back of the watch off and inspect the works. If you have to pay a watch shop to diagnose and fix the issue you are probably better off just replacing the watch. The labor bench charge in most shops for one hour will probably be more than what you paid for your watch. If you are not sure it might be worth contacting a few of your local shops to see what they would charge to diagnose the issue.
Mar 06, 2011 | Timex Indiglo Analog Watch
Display disappears when Indiglo is pressed
That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
Feb 19, 2010 | Timex Watches
Indiglo light does not light
Replace the battery for Indiglo function.
Feb 16, 2010 | Timex Expedition 84601 Wristwatch
My Timex Indiglo 466w does not ligt anymore
i WAS TOLD BY TIMEX THAT IT WAS TOO OLD ...I GUESS I'LL JUST USE IT IT A DAYTIME AREA
Dec 18, 2009 | Timex T276B Clock Radio
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
Timex T49271 Expedition Indiglo button dead?
There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
Hope it may helps you;
Regards
VOTIT
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
Timex T600 Clock Radio Logo
44 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
