Question about Candy DFI Plan Built-In Dishwasher
My candy dishwasher flooded npand then cleared and now only runs for two mins then stops n starts bleeping
4 Suggested Answers
  • 4 Answers
SOURCE: Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Posted on Oct 04, 2009
  • 3247 Answers
SOURCE: I have a candy cdi
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Posted on Oct 11, 2010
ercupa190
  • 12223 Answers
SOURCE: DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
Posted on May 10, 2012
It starts the cycle then it drains down and the bleeping starts saying theres a fault.
MAY BE A LEAK AND ITS ACTIVATING FLOOD SWITCH WHICH WIL DRAIN MACHINE TO STOP FURTHER LEAKS CHECK SEALS AND MOTOR SEALS FOR LEAKS
Jun 17, 2012 | CDA WC430 Dishwasher
God bless you
May 09, 2012 | Candy Dishwashers
My candy dishwasher is CDI505-S,and the problem is that in the coutdown button appeared E4 and the machine doesn'run,please what can I do......
It is most likely that there is flooding in the dishwasher due to water leakage.
This information thread from another model might be helpful in solving the problems.
Good Luck.
Jun 01, 2011 | Candy Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Oct 11, 2010 | Candy Dishwashers
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
hope this helps
regards JL
Oct 04, 2009 | Candy Dishwashers
Aeg favorit 86070 vi fully integrated dishwasher started bleeping with 3 short bleeps 2 months ago. I followed instructions internet and shook dishwasher to one side and it worked for about 8 weeks. Now...
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Sep 09, 2009 | AEG 23 in. Favorit 86070Vi Built-In...
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Candy DFI Plan Built-In Dishwasher Logo
64 people viewed this question
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
