Question about Jamo SUB-650 Subwoofer
Fuse problems - Jamo SUB-650 Subwoofer
What fuse do i replace to make my windshield wipers work Chrysler 300
Highly doubt the fuse being the problem . If the fuse is blown ,that circuit has a problem , short to ground , wiper motor drawing to much amprage . Fuse's do not blow for no reason . Fuse # 18 -30 amp . under hood fuse box . There is also a relay , wiper on/off relay in same under hood fuse box . Also wiper hi/low relay ! There is also alot of electronics involved . integrated power module , front control module , plus C.A.N bus network . How to Diagnose Controller Area Network CAN . Could be wiper / washer switch , wiper motor , communication problem , module problems , Relay problem . Google chrysler intergrated power module . they have had a lot of problems with that thing .
Oct 12, 2015 | 2006 Chrysler 300
Windows won't roll down, and it won't auto lock,
There are fuses for both windows and door locks, If fuses are good may be electrical problems
Sep 23, 2011 | 2001 Mercury Sable
On my girlfriend 2000 dodge durango , her dash lights and her tails lights do not work any more. i check the fuse like 4 times !! i just need to know wats some other places i could look for the problem ? ...
The dash lights & tail lights are on the same fuse circuit. If you have meter tested the fuse or replaced the old one with a new one and still have no lights remove the fuse and test the fuse block to make sure there is power going to the fuse. If no power is passing through the fuse block slot then the problem is the hot wire going to the fuse block. If the fuse block has power the problem is a hot wire between the fuse block and one of the bulb connections. Either way you need to use a multimeter and test the wiring and or bulb sockets until you find the problem. If you do have power at each socket then the problem is a loose, broked or corroded ground wire. Don't get frustrated, these kind of problems can take a while to sort out.
Feb 20, 2011 | Dodge Durango Cars & Trucks
Why wont my dashboardlights and radio not work. I have cheecked the fuses.
Did you check for battery power at the fuses, or did you give them the "Eyeball Test". The two fuses involved in your problem are fuse "O" and fuse "H". Fuse "O" will only have battery power when the ignition switch is in the "ACC" or "ON" positions. Fuse "H" will have battery power at all times. If both of these fuses have battery power when they are supposed to, the problem is probably your illumination control switch is either defective or turned off. If fuse H has no power, the problem is in the main wiring harness between the battery and the fuse block. If fuse "O" does not have power when it is supposed to, the problem is most likely your ignition switch.
Jan 11, 2011 | 1994 Nissan Sentra 4-Door
Clock and dash lights dont work or radio--
These items clock, radio, dash lights are usually fused on the same circuit. Please check the fuses for this problem. The fuse or fuses should be listed on the fuse box cover inside the interior fuse box. Replace the blown fuse if that is that problem. If it blows again, then the cig lighter circuit may be involved. Make sure the cig lighter is free of any objects, remove lighter, (push in part). Try new fuse while lighter is out, and if problem goes away, push in may be bad.
Oct 31, 2010 | 1998 Honda Accord
Radio not working
It is the fuse inside that yellow fuse holder on the lower left side that is bad. Not the one that says audio that is the problem you can not see the fuse but it is in that yellow holder.
Apr 06, 2010 | 2003 Hyundai Tiburon
Wind sheild wipers dont work.
For wind shield wiper that does not work, here's what you need to check:
1. First the fuse.
2. Wiring.
3. Switch
4. Last, is the motor.
Thank you!
Dec 31, 2009 | 1995 Ford Windstar
Blown fuses
you are going to have to look in your owners manual to tell us what fuse it is,
Dec 20, 2009 | 1996 Chevrolet Blazer
Car fuse problem
Fuse problems are the cause of many strange problems with your car, here are a few fuse problem solutions. If you are suffering from No power to radio, cigarette lighter, here is your solution, another FixYa solution about power problems, that will prove helpful is here. For Remote control or key fob problems this solution should do the trick. For dash light illuminating this solution might give you a clue.
Fuse problems - can be replaced by you quickly, easily, and with little to no dirty hands, & most important of all can save you money. Good luck with your fuse problems, hope this thread helped you, if you find new, or better solutions please post them here.
The car fuse box is usually found in one of two places: usually near the bottom of your dashboard as you move closer to the foot well or, on some models, under the hood. If you are having trouble finding the car fuse box, have a look at your car manual.
Good luck.
Jun 29, 2008 | 2004 Toyota Corolla
Blowin fuses
it is always best to have fuse on battery lead but as long as the leads are definately going through the fuse panel then you should have no problem but if you have the fuse and it blows then their is deffinately something wrong.
The fuse on the battert leads is a backup as long as the wires are running through main fuse panel the reason for extra fuse is because the main fuse works other things running off it not just the one for radio so the fuse on the battery lead is their so that if something wrong with the unti then that fuse blows and only that 1 unit wont work but if main fuse blows other things might not work so its always best to have inline fuse so that only the 1 unit stops working incase of problem.
so its not vital you have one but it usefull so that you know where the problem is coming from and saves time tracking down fault
Jan 11, 2008 | Panasonic CQ-DFX972U CD Player
Jamo SUB-650 Subwoofer Logo
23 people viewed this question
Top Jamo Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
rjivaro
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
