Question about Garden
Changeing engine oil on mountfield sp414
Engine oil change
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Change the Oil
the easiest way would be to purchase a manually pump up oil change device that draws a vacuum and you put the tube from that device in the oil fill hole and draw it out to its own container
Posted on May 25, 2009
mowerman1857
  • 389 Answers
SOURCE: how much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
Posted on Sep 15, 2009
kel1guy2002
  • 3740 Answers
SOURCE: have a mountfield honda GCV135, need to change oil
Here is the manual.... : http://www.smallenginewarehouse.com/images/manuals/GCV135-160.pdf
On page 28 of the pdf file it says you have to shut off the fuel and then remove the oil filler cap/dipstick and then tip the engine to drain the oil.
Air filter cleaning procedures are on page 31 of the pdf file.
Thanks for using FixYa.
Kelly
Posted on Jul 05, 2010
Mountfield manor 95h oil change
ask dealer this a all gear two wheel drive mower tiller and other things it probably use a special gear oil the engine uses just plain 30 weight not 10w 30 just 30 weight
Sep 03, 2014 | Garden
My mountfield sp414 keeps cutting out
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward.
Apr 29, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
How do you change the oil in a mountfield LS45 Lawnmower???
While I am not familiar with this brand, typically, in a four cycle lawn mower engine, there will be a oil drain plug in the bottom of the engine or on the lower part of the engine above the deck.
Thanks for your question @ FixYa.com
May 19, 2011 | Garden
After the machine has been running for about 45
Have you checked the oil? many motors have an oil pressure switch. When did you last change it? if the oil gets hot and thin, there is less oil pressure. Could also be a safety switch, vibrating loose. Switch on seat maybe?
Jul 12, 2010 | Garden
Have a mountfield honda GCV135, need to change oil but cant find the plug? and want to know about air filter cleaning?
Kelly
Jul 05, 2010 | Garden
How do I change the oil in a Mountfield Emperor Lawnmower? I can't see where to drain it.
the drain plug is located under the mower. above the blades. just look for a freeze plug that you can fit a 3/8" ratchet into. Remove the plug, wait for the oil to drain, then replace the freeze plug. You might have to get a water hose and wash the under carriage out and get all the grass off before you'll be able to see it.
Sep 20, 2009 | Garden
How much oil does a mountfield omega lawnmower take
Sep 13, 2009 | Garden
Change the Oil
May 25, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
