Question about Polk Audio PSWi225 Subwoofer Speaker
Speaker parts receiver for Polk Audio PSWi225 Subwoofer Speaker
SOURCE: Attaching speaker wire to my speakers
most speaker wires have a red and black marked on them,or half grey with black you also get a plus and minus on them black is plus while the grey is minus
Posted on Sep 07, 2007
fcollingwood
  • 58 Answers
SOURCE: subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Posted on Sep 14, 2007
lynchms
  • 93 Answers
SOURCE: best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Posted on Feb 12, 2009
  • 308 Answers
SOURCE: Polk Audio PSW202
The power supply or amplifier has a shorted component.
Posted on Mar 12, 2010
  • 40 Answers
SOURCE: Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Posted on Mar 26, 2010
Help with repairing this product, Polk suggests replacing the amp !!
To troubleshoot this you need at least an ESR meter. Capacitors can fail with no outside indication.
Jun 19, 2016 | Polk Audio DSW PRO 500 Subwoofer Speaker
NEED REPLACEMENT NON OEM REPLACEMENT WILL WORK WITH POLK AUDIO WIRELESS SUBWOOFER PSWi225
sq nearest expert radioinstaller I'm sure he will know the answer and have the replacement part you need
Feb 08, 2015 | Polk Audio Audio Players & Recorders
I'm looking for the transmitter for the Polk Audio PSWi225 wireless subwoofer
i have the transmiter and no sub.Got it in a box of left over parts from ultimate electronics when they went out of buisiness in arizona
Aug 17, 2013 | Polk Audio PSWi225 Subwoofer Speaker
Subwoofer set up polk audio 6750
Connect the subwoofer to an amplifier/audio receiver with the proper cables. Reply back with your setup so I can get some more information.
Dec 25, 2011 | Polk Audio Audio Players & Recorders
Loud humming sound from subwoofer PSW111 (specially(noticeable once AV receiver is off).
Check the connections from your reciever to your subwoofer. It sounds like they may be a little loose.
May 15, 2011 | Polk Audio PSW111 Speaker
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
Add su bwoofer to KLH 200
the subwoofer i have, a polk, connects directly to the right and left speaker lines of the klh2400.
i then connect my stereo left and stereo right speakers to the subwoofer.
essentially, the subwoofer becomes a middle station between my speakers.
make sense?
Jun 06, 2009 | KLH KL2400 Tuner
Best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
Feb 11, 2009 | Polk Audio PSW10 Subwoofer
How connect subwoofer to onkyo 8522
does it have speaker wire in and out use then from fronts
Feb 04, 2008 | Onkyo TX-8522 Receiver
Polk Audio PSWi225 Subwoofer Speaker Logo
20 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
