Question about MSI K7N2G-ILSR (MS-6570G-020) Motherboard
Won't Boot up
I was trying to over clock and now it won;t reboot. can you tell me how I can reset to defaults? K7N2G
    President:
  • 2,961 Answers
You need to locate the JBAT1, CLRCMOS,CLRCLK, or similair terminals to clear the cmos settings or try removing the cmos battery, althogh you may need to do both as this will set the clock speed back to default
Posted on Oct 11, 2007
SOURCE:
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
Keypad won't work sideways on my zte warp
Try resetting the device to factory defaults and that should resolve the issue. Please make sure that you have a back up of all the information and the SD card is removed before resetting it.press Menu Key > Settings > Privacy > Factory data reset > Reset phone(Don't check Erase SD Card)> Erase everything. The phone will reboot automatically.
Jan 15, 2013 | ZTE Warp
My straight talk LGL55C powers up and goes to the blue tracphone blue screen and won't power off with power button or anything
Take the Battery out.
Place it back in.
Press and hold the Vol down : Home : Power buttons simultaneously for 10 sec.
Using the volume buttons navigate to the reset to factory settings option.
press select (left of home on L55C).
Confirm to reset.
Select to reboot.
You should be good.
Oct 30, 2012 | Cell Phones
After cmos button reset won't boot
Go back into BIOS and set defaults. Take a look at hard drive while there. I have a similar model!
Oct 22, 2012 | HP Compaq dc5100 PC Desktop
Polycom IP 501 won't reset to default when using MAC address as password
If your phone isn't on a constant reboot cycle and can boot up, then go into Admin Setting and do a Format File System reset. NOTE: Only try this if you know how to download the software files onto the phone via FTP server. Once you download the latest software your phone should be almost as good as new.
Sep 19, 2012 | Polycom SoundPoint IP 501 IP Phone
Ydi ap plus won't reload factory defaults
Try This:
    • 1 Unplug all cables from the router except the power cable. Power on the router.
    • 2 Locate the reset button. This is typically a small hole marked "Reset."
    • 3 Insert the straightened end of a paper clip or the point of a ballpoint pen into the hole. Press and hold for about 10 seconds. Lights will blink, indicating that the unit is rebooting.
    • 4 Refer to your user's guide and follow instructions on setting up a new router.
Aug 01, 2012 | YDI Computers & Internet
Cant access bios to change boot order to reuinstall windows 7
Boot the computer and watch the screen. It will tell you what key to hit to get into the Bios or System Setup. You have to hit the key when you see the message or it won't work and you will have to restart.
It also shows you which key to hit to change the Boot Sequence or Boot Order. But you have to hit the key when the message appears on the screen or it won't work and you'll have to reboot. This is a temporary 1 time change for the current boot cycle. When you change it in the Bios or System Setup it's a permanent change.
May 25, 2012 | Computers & Internet
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
MSI K7N2G-ILSR (MS-6570G-020) Motherboard Logo
266 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
