Inotec mw 7152 - Televison & Video
Quickbooks pro 2005 will not run in windows 2007
This usually means the .Net framework is damaged.
Look for a file on the cd called dotnetfx and run it.
Feb 16, 2013 | Intuit QuickBooks: Pro 2005 for PC
Inotec mp 5620 tv show blue screen with red pad lock
Hi Khalid881,
There are a few similar issues like this but with different brand televisions.
If you have the remote, try holding down the "Display" button for 5 to 10 seconds.
I'm assuming you have a display button though, it could be called something else though.
Sorry if this doesn't help but it's worth a try.
Myke
Feb 22, 2011 | Televison & Video
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
How do I remove my ge jvm 1653 microwave?
Clean out the cabinet above the micro wave and you will find 2 or 3 bolts that secure the unit (MW) to the bottom of the cabinet. They will normally be towards the front of the cabinet.
I always put a towel or cardboard over the surface of the range for protection and a place to set the MW once it is ready to come down.
Have someone either hold the MW up by putting pressure upwards on the front of the MW or take the screws out. (don't forget to unplug the MW)
Gently let the front of the MW fall forward about 6" to 8" and lift the back of the MW upwards and it will release from a mount that is attached to the wall.
You may feel a little resistance as it might be duct taped to the exhaust going up or out the back.
Be aware that these older micro waves can be a little heavy and it is recommended that 2 people are used to do this.
Apr 09, 2010 | GE JVM1653 Microwave Oven
Need Authorization Code for Photoshop CS2.
Check this out...
Authorization Code is:
0669 3196 0902 8300 7881
Aug 29, 2009 | Adobe Photoshop CS for PC
What is the range of blootooth in meter.
The range of a Bluetooth device depends on the Radio Class. I am not sure what the Class on a BlackBerry Curve is, but here are the options:
Class Maximum Permitted Power mW (dBm) Range (approximate)
Class 1 100 mW (20 dBm) ~100 meters
Class 2 2.5 mW (4 dBm) ~10 meters
Class 3 1 mW (0 dBm) ~1 meter
Jan 22, 2009 | RIM BlackBerry Curve 8310 Smartphone
Will using a 400 mw charger adapter instead of a 300 mw hurt the
Good To Go Some May Disagree But Its Not Gonna Make A Difference.
Jan 06, 2009 | Radio Shack Pro-99 Handheld Scanner
Find glass turntable replacement part
These are the glass trays listed to match the models you gave (NR961T is actually MR961T) and they are all shown as no longer available from standard suppliers:
MW-7600-04 MW-7600-06 MW-7600-11 MW-7600-13. MW-7600-12 should also work.
You can order one of the -11 or -12 trays by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. Here;'s a photo of that, too.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Welbilt MR755T Microwave Oven
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
