Question about ViewSonic VP181 18.1" LCD Monitor
Viewsonic VP181 power adapter barrel jack size
I need to buy a 12V 6.5A AC/DC power adapter for my Viewsonic VP181 LCD monitor.  Does anyone know what barrel jack size is required?  Is it 5mm/2.5mm ?
  • 5 more comments
  • Amander Jan 27, 2008
    I need a power adapter for the same monitor. WHERE DO I FIND ONE?!?!? Please???
  • mimeson Feb 22, 2008
    I need a power supply as well. Searched eBay and Google and ViewSonic without any luck.
  • Anonymous Mar 17, 2008
    5mm/2.5mm ?
  • Connie Beatty Apr 13, 2008
    I need the same power supply cord and have looked at many online sites without any luck. Does anyone know where one can be purchased??
    I am having the same problem. I need to buy the same power supply cord and have been unable to find one online. Does anyone know where to purchase one of these??
  • jaymil Apr 18, 2008
    Thanks for the web site source for this adapter. I will try the 12V 6A adapter. Note that if you select the adapter by LCD type, the 12V 5A adapter will be chosen for the VP181. I don't think this is correct, the amp rating required is 6.5 amps. The 6 amp adapter should hopefully work without getting hot.
  • Cerius Black May 21, 2008
    I also need a power supply as well. Searched eBay and Google and ViewSonic without any luck.
12vAdapters.com has the right adapters.
Posted on Apr 17, 2008
Yes. it is a 5mm center hole
Posted on Dec 18, 2007
SOURCE:
Where can I get a power cord for the ViewSonic VE700 LCD Monitor
Hello there:
Most of the computer stores or a electronics store like office depot or radio shack or walmart or k-mart ect ect ....will have these cords
Furthermore if you have a second hand store in your area they might have them there too
Hope this is very helpful for you>
Best regards Michael
Jan 05, 2010 | ViewSonic VE700 17" LCD Monitor
Need tip size for viewsonic powere supply
insidecomputer_2070_4186448
Replacement Part Number: 1267-0526
Specs:
  • 40 Watt, 12 Volt AC Adapter
  • 4.8 mm Barrel Connector with Positive inside
  • Condition: New
  • Warranty: 12 Months
  • 100% OEM compatible, Guaranteed to meet or exceed OEM specifications
Compatible Models:
  • Hewlett Packard Jornada 680 Series
  • Hewlett Packard Jornada 720 Series
  • Hewlett Packard Jornada 728 Series
  • HP Jornada 680 Series
  • HP Jornada 720 Series
  • HP Jornada 728 Series
  • Planer LP150-BK
  • Viewsonic VG150
  • Viewsonic VG-150B Model
  • Viewsonic VG151
  • Viewsonic VP140
  • Viewsonic VP150M
Sep 07, 2009 | ViewSonic VG151 15" Flat Panel LCD Monitor
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
I dont know about capacitors or regulators i just need to know how to turn this thing on.
on the specs from ebay I see you need a 12v dc 5 amp ac power adapter .
normally they have an led , but if you can't get power you will have to verify that you have the 12v at the tip, you will need a multimeter or 12v bulb connected to the end.
if your getting power then the panels circuit is at fault.
talk to a local geek about checking it out.
Mar 28, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
AC/DC Adapter
Hi, You would need an adapter that puts out 12 Volt DC, Output Current: 3.3 Amp and the Center Positive Power Tip (Output Power: 40W). The original ViewSonic adapter is M/N: UP06031120A Hope this be of some help/idea/ Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Replacement External Power Supply
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Jan 06, 2007 | Planar PL2010M 20" Flat Panel LCD Monitor
Need AC/DC adapter for monitor!
Hi inkedpandora, http://icm.computercci.com/pgi-productspec?PSO080 This one should work for you it's the same voltage and amperage as your unit. 19VDC 3.16A Any standard power cable from an old printer or computer will work with one of those PS's. The only thing you need to check before you buy is the polarity of the barrel connector. I looked on the net but could not find out that info so look at the jack where the power plugs into the monitor. You might see a little diagram showing a + and - signs. If the line coming off the + sign goes to the semi-circle than the barrel is positive and if the - goes to the SC the barrel is negative. Ask them before you buy which way that one is. As long as they are the same you will be able to use that PS. Good Luck, Dude
Nov 22, 2006 | Liquid Video A170E101 Monitor
ViewSonic VP181 18.1" LCD Monitor Logo
809 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
