Question about Sewing Machines
Bernina 450 bobbin winding motor failure - Sewing Machines
RickE1
  • 202 Answers
SOURCE: Bernina 145 Bobbin winding problem
If the winder is working without thread as it should you can rule out an electronic and motor issue. At this point it won't hurt to remove the two screws on top and lift your top cover off. Take a close look at your winder and see if there is any thread or anything wound around or blocking it. There are one or two screws that will adjust the eveness of your bobbinwinding but I don't think this is part of the problem (just a slight turn for that until the bobbin winds evenly). There is a spring beneith the winder that may have popped loose, check that but if the little arm snaps back and forth thats ok. The spring should be in the second tooth of the gear notches.
I hope this helps.
Posted on Jul 31, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 180 - winding thread onto bobbin spool
Also it is quite possible that the small circuit board (P-print) just below the bobbinwinder that the motor plugs into has gone bad.
Posted on Nov 27, 2008
SOURCE: toyota sewing machinge 5500
If I understand the problem, the bobin winder has probably lost a rubber 'o' ring.
Unscrew the two top screws and remove the top cover. At the base of the bobin spindle is a metal disk that should have a rubber 'o' ring on it. This will perish over time and break off.
When the bobin winder is pushed sideways into the active position, this should contact the main turning handle thingy (that's a technical term) and be spun around. Check if the bobin 'o' ring is making contact or if it is even there at all. Any sewing machine repair shop (or good automotive store if you're desperate) will have a replacement.
Posted on Dec 06, 2008
  • 2976 Answers
SOURCE: when winding the bobbin the bobin wont spin ,the
Make sure you either tighten the knob or push in the wheel on the right end of the machine, at the hand feed wheel.
Posted on Aug 13, 2009
  • 11 Answers
SOURCE: I own a Bernina Deco
Make sure that the bobbin is pushed all the way down and that you hold the loose end of the thread as the bobbin starts to wind.
Posted on Mar 17, 2010
My Bernina 440QE will not wind a bobbin.
Hmm, I have a 440 bur have not had this problem. However, I do most of my bobbin winding on a standalone bobbin winder (called Sidewinder). They are available several places, JoAnn's, Amazon, etc. for about $30. You can get one that will take batteries or a power cord. Saves wear n tear on your machine, plus you can wind multiple bobbins quickly, and you don't need to unthread your machine. Just an idea.
Mar 01, 2018 | Bernina Sewing Machines
I have a 910 bernina which will not wind a bobbin anymore, what should I do?
Which question are you asking? How to wind a bobbin or how to install a bobbin?
BERNINA Sewing Systems
Sep 11, 2016 | Bernina Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Bobbin Winder has quit working
Drive belt broken or motor has failed. SOme machines have a separate motor to wind bobbins.
May 19, 2014 | Bernina Artista 180
I have a new Bernina 350 and the bobbin doesn't wind on evenly. If left to do it automatically it ends up wrapped around the bobbin spool. Is this normal?
the thread has to be pretty tight around the bobbin tension guide
but I would suggest if you can't get it to wind correctly to have it check to see if there is a problem with it
May 12, 2012 | Bernina Sewing Machines
Bernina 135 bobbin winds unevenly
If you are finding that the bobbin is winding with more thread towards one edge of the bobbin than the other, the bobbin winder motor needs to be adjusted so that the angle of the winder shaft is properly aligned with the tension disc next to the head cover. Unfortunately, unlike many of the other models, you have to remove the covers on the Activa range to get at the adjuster. There is a spring-tensioned screw just to the left of the bobbin winder motor that adjusts the angle of the motor and therefore how it loads the bobbin. If the winder is loading the bobbin with most of the thread towards the bottom edge, the screw should be turned clockwise and if most towards the top, it should be turned anticlockise. Make adjustments until the thread is winding evenly or, at least, towards the centre of the bobbin.
If you are finding that your bobbin is being loaded somewhat randomly, make sure you are using the vertical spool holder to hold the spool and that you've got a foam pad under the thread spool. Route the thread through the thread guide before winding around the tension disc in the correct direction (see the arrow on the case) and ensure that the spool and thread do not vibrate unduly when the bobbin is being wound. If you let the spool vibrate whilst the bobbin is loading, it may result in varying tension on the thread and uneven winding onto the bobbin.
Oct 02, 2011 | Bernina Activa 130
If the bobbin winder spindle turns freely by hand and the macine runs fine with the foot controller then it may be the small motor that runs the bobbin winder that is at fault. If this is the case then your local service tech should be able to relace it. It is not a very costly part so don't be to worried.
Nov 02, 2008 | Bernina Artista 180
Winding on bobbin thread
Have you checked your manual?
Sep 16, 2008 | Bernina Activa 130
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
