Question about Sewing Machines
Yamata fy747a cant change needle
Can't find needle size for my machine
Try an industrial supplier... especially one that sells Yamata.
Nov 11, 2012 | Sewing Machines
Where can I buy a needle bar for Yamata FY 5813 industrial sewing machine?
How about an industrial sewing machine supply? Allparts has some parts for Yamata... great folks to work with.
http://www.allbrands.com/search?search=yamata
Sep 24, 2012 | Sewing Machines
SERVICE MANUAL FOR YAMATA FY8700 INDUSTRIAL SEWING MACHINE
my thread deeps bursting, tension is normal. what to do?
Sep 24, 2012 | Yamata Sewing Machines
THREAD COLLECTS UNDER MY YAMATA FY 760
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for loose threads or lint
check to make sure the bobbin & bobbin case is not damaged
May 17, 2012 | Yamata Sewing Machines
I need a needle bar for my yamata fy8500 where can i get one from
here are some websites that have parts
sewandserge.com
amapparelsupplt.com
yamata.com
Dec 16, 2010 | Yamata Sewing Machines
Yamata FY7568 Machine not sewing
Make sure the correct needle is installed on the machine. Domestic needles will have one flat and one rounded side on the shaft. Make sure the flat side of the needle is on the back and the groove on the needle also being to the back.
You might also want to make sure the tip of the needle is not broken.
Other than that, your machine could be out of timing.
Jun 19, 2008 | Sewing Machines
Bobbin case
Make sure there is no fabric or thread on the bobbin case shaft. Needle has to be in up position.
Feb 19, 2008 | Yamata FY811 Mechanical Sewing Machine
Needles keep breaking
Sew paper.If ok try buying from reputable Haberdashery packets come in various sizes. Maybe material is to thick for needle
Jun 29, 2007 | Yamata FY920
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
