Question about Stihl Br 500 550 600 Backpack Blower Throttle Cable Assembly 42821801100
Engine wont rev up
The carby is not priming properly and will not rev even when i lean it off,the rev only go a little on full throttle
  • 6 Answers
Mine was starting and running weak then cutting off after a few minutes,,, after changing plug, air filter and having the carb cleaned ... it ended up being bad ignition cable that fixed it.
Posted on Feb 07, 2015
The fuel system is blocked up
perhaps the plug is bad
and the air filter will need replaced
or the fuel tank vent is also blocked up
Posted on Dec 04, 2014
Wont rev ups ticks over , but just dies out when throttle opened
Blocked air filter / Blocked Main Jet in carbie / Power Mixture set to lean /
Mar 31, 2014 | Garden
My chainsaw will run only full throttle and when you let of of the trigger it wont idle it will die
Hey on the carburetor there is 2 mixture screws 1 is for idle up to 1/4 throttle the other is for 1/4 to full throttle the one for idle is closest to the engine. screw it all the way in then unwind it 1 turn. The screw the furthest from the engine screw it all the way in then unscrew it 1 1/4 turns Try to start the saw with just a little throttle. this setting is pretty standard. When you get it to idle then rev the saw and it cuts out as it returns to idle it's running to rich. Just adjust the screw in a little say 1/8 at a time. When it's to lean as soon as you throttle on it will stall. If you have no luck with this...you have a air leak from the carby gasket or the bolts are loose or a blocked exhaust
Oct 14, 2013 | Earthquake Gas Chainsaw, 14 inch CS3814...
Wont hold an idle revs up and down
Hi, Anonymous and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue please click on the blue links below. Good luck and have a wonderful day.
How To Fix 5 Common Bike Issues RideApart
http://www.thegsresources.com/_forum/showthread.php?181491-Bike-in-idle-and-rpm-s-go-up-and-down-then-stall
Total Motorcycle Forums
You wont get this engine revs by itself
Symptoms of Lean or Rich carb settings on motorcycle
Apr 10, 2017 | Motorcycles
1987 Chevy 1 ton 350 V8 After a little while of idle (Perfectly) It'll rev its self up all by it's self and Idle at a higher Rpm
check for leak at base of carby. It sounds like the idle mixture is leaning out. check for corrosion at gaskets or loose carby body
Jan 08, 2013 | Ford F-150 Cars & Trucks
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Need to know then factory settings for the carburetor on a 78 it 250 e...how many turns out for the idle and how many turns out for the air/fuel mix?
I have the H model and set mine at one and a half turns out from stop. It waivers a little from summer to winter but only by a fraction.
As for the idle speed, when bike is warmed it will idle a little different to when cold and using choke.
Personal preference really, without a tacho fitted, I set it so she idles easy when cold. Once she's warm, idling is generally not used!!
To balance the two, warm engine and hold throttle at your optimum idle speed. Screw in idle adjuster until it engages base edge of carby slide. Release throttle and screw in/out fractionally to test if revs rise/fall. Set at optimum and then turn air mixture screw in/out till revs are highest (without using throttle). Then reset Idle screw back out to bring revs down to optimum level.
Tip, use a little thread seal on the idle screw as they have a nasty habit of unscrewing and leaving a hole in the side of your carby...sure fire way to lean right out and burn a hole in your piston when riding.
Cheers.
May 21, 2010 | Motorcycles
I cant start the bike
There is a proper way to start the engine. Four controls are on your bike to assist in starting. Below are generic instructions.
  • The choke, used when the engine is cold. Pull the red knob for choke.
  • The " Hot Start " Lever, used when the engine is hot. Pull the lever to lean the fuel mix when the engine has been running.
  • The de-compression lever, always used.
  • The throttle, used to prime the cylinder.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. A flooded engine will often backfire. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), for six kicks. After six kicks go ahead and twist the throttle again for a second priming. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Nov 14, 2009 | 2006 kawasaki KX 250 F
Fuel Air Adgustments .What they are Set at.& Which are which?
The air looks after itself when you operate he throttle. This how you adjust the fuel....There are two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time. Start with H (high) with the saw at full revs. Turn anti clockwise untill you get max revs then turn it back a little bit. If its running too lean it will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Sep 07, 2009 | Garden
1977 Suzuki TS185 throttle sticks
Could be 2 things to look at first.1 the idle adjusting screw has been screwed in to far and is holding the throttle slide open.The other is an air leak between the carby and the motor resulting in the air/fuel mixture being to lean.This would cause the revs of the engine to be to high.Check these 2 things.Hope this helps
Aug 15, 2009 | Suzuki TS 185 Motorcycles
Difficulty starting Poulan 2250 . . .
hey pete
This is easy, prime bulb 5 to 7 times with choke lever full out. Pull string, once engine starts turn off choke and pull string again. ( throughout process do not pull trigger )Engine should start, let it idle 30 seconds, then finally pull trigger to rev up engine.
Jul 03, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Stihl Br 500 550 600 Backpack Blower Throttle Cable Assembly 42821801100 Logo
354 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
