Question about Police Watches
Broken push button on chronograph watch 12086j
SOURCE: tag link chronograph
It sounds like the button is not making contact with the movement curcit board. Take it to a watchmaker who has a pressure tester so he can look and see if in fact this is the problem, and then can re-seal your watch to the exact number of meters your watch can go diving to.
Posted on Jun 29, 2008
SOURCE: Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
Posted on Mar 24, 2009
SOURCE: my michele watch chronograph is stuck
raebarb,
I had the same problem, you can fix it without an expensive watch maker. The online instructions are not perfect, but are better than the ones that come with the watch. Go to www.michele.com/.../Michele/.../instructions/michele_instructions.pdf
Refer to page # 10 "Adjusting the Chronograph Hands to Zero Position" even though these instructions refer to adjusting only 2 hands on a different model, with a little playing around you can reset all 4 hands. The trick is to pull out the stem, 2 clicks to position III and then using buttons A and B. You will have to do the 2 hands then push the stem back in. Repeat the process and reset the other 2 hands.
Good luck, YOU can do it, I just did.
Fingers Cramer
Posted on Jul 02, 2009
  • 2501 Answers
SOURCE: chronograph watch buttons do what?
I assume that you do not have the instructions for this watch, so you need to obtain a set or visit your local dealer.
Enter "www.tudorwatch.com" into your search engine to go to their website.
At the welcome screen select "welcome" (this selects the language).
At the top of the screen select the option "dealers" and contact them and ask them for a set of instructions for your model. (I was unable to find any option to download instructions, so contacting the dealer seems to be the only alternative.)
Posted on Jan 13, 2010
  • 299 Answers
SOURCE: watch is working fine but the chronograph is not
sounds like it needs to be serviced under warranty. The clutch mechanism maybe jammed or broken.
Posted on Apr 27, 2010
How it works invicta clock mechanism ?
Your watch is battery powered or a 'quartz' watch. It is commonly refered to as a 'chronograph'. That is another word for stop watch.As well as telling time and the date, your watch can time how long an event lasts. For example, a horse race. You start the chronograph or stop watch when the horse starts and stop it when it crosses the finish line. When the next horse starts you need set it back to zero to time the next race.Operation is simple. The upper push button starts and stops the chronograph. Try it. Now with the chronograph stopped, push the bottom button. The hand return to the 12 o'clock position or the 'zero' position. Also notice the small dials on the dial or face of the watch. They record minutes and other increments of time. The large hand going around when you push the upper button is recording seconds. Hope this helps, Michael
Oct 09, 2012 | Invicta Lupah Collection Chronograph #9813...
How do I get the second hand chronograph to move?
The upper push button starts chronometer when pushed once. Second push on the same push button stops it. Lower push button returns chrono hand to zero.
Feb 26, 2011 | DKNY -Dial Chronograph Watch for Women
Coutura Chronograph Watch: set the alarm on a coutura chronograph...
pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 17, 2010 | Seiko Coutura Chronograph Watch
Watch is working fine but the chronograph is not
Apr 26, 2010 | Sector 2653940025 Wrist Watch
Fossil Chronograph--need to know what the two buttons on the side do
Two push buttons is for chronograph function. When you push the upper button - chronograph starts, second push on same button - stops the chronograph. Push on lower button - chronograph resets to zero. Rate me, plz.
Feb 03, 2010 | Watches
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Need to know how to operate Cartier Tank Francaise Chronography W
The top button is for chronograph function and puts the chronograph seconds hand in motion. The bottom button is for resetting chronograph seconds hand to zero.
Do as follows:
1) push the top button once- seconds hand starts moving,
2) push the top button once more- seconds hand stops,
3) push the bottom button once- seconds hand returns to zero.
You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
Do not forget to rate, please.
Jan 10, 2009 | Cartier Tank Americaine W2601156 Wrist...
Timex expedition
HI
HERE IS SOME STEPS FOR YOUR DOUGHTS......
Set the chronograph. Push the bottom left button until you see the word "CHRONO" on your watch. Press the top right button to pick "Lap" or "Split." Press the top right button to start or stop the timer.
Press the bottom left button to see your lap or split time. Press the bottom left button to pause the timer. Press the top right button to start again. When you're finished, press the bottom left button to stop timing. Push it again to reset it your chronograph to zero.
THANK YOU
Dec 12, 2007 | Timex Digital Expedition watch
Watches Logo
19 people viewed this question
Top Police Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Tom Chichester
Are you a Police Watch Expert? Answer questions, earn points and help others
