Oe error code lg washing machine f1403fd
No conditioner added during any cycle
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
  • 73 Answers
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Posted on Apr 29, 2009
MNTECH
  • 1543 Answers
SOURCE: OE error
First, open the small access door at the lower left on the front of the machine. Use the small hose to drain the remaining water out of the machine. Then, unscrew the big knob to remove the filter and clean out any obstructions there. If you have the "OE" error code, which is really a "DE" (drain error) code, and you have checked the filter and it is clear, then most likely the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. You can reach through the large hole in the bottom of the washer base to access the pump. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 5.5 or a 6.
Posted on May 01, 2009
SOURCE: LG washing machine displaying error
It's actually a DE error code which stands for drain error. Pull the little basket out that's behind the small door on the lower left front (where the drain hose is) and look inside. The drain pump intake is about an inch in on the left. Make sure there's nothing in there like a paperclip or hair pin. If possible reach in and see if you can turn the impeller. If it won't move there's something in there if it will turn then the motor is probably bad.
worked for me
got this from mark1963
Posted on Jun 06, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
Lg di dvr 9kg does not spin.ser no f1403fd[oe comes up in window,to stop program]what should i do.
Hi cheyrlsouthw,
OE error is Outlet Error. You will need to clean the Pump Filter, as it is most likely clogged by a foreign object. Check your Manual for instructions on how to do this.
Kind Regards
If you found this solution helpful, please rate accordingly :-)
May 18, 2011 | LG Washing Machines
My washing machine stops mid wash and on d LCD display it has the letters OE sometimes the machine doesn't spin an if t does the cycle it doesn't let the fabric conditioner go n the was
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. Clear the filter located on the bottom left on the face of the machine. You will find a access panel located there that you need to open. richroth_61.gif Happy Holidays The FixYa Team
Dec 19, 2010 | LG Washing Machines
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Sep 03, 2010 | LG WM0642H Front Load
Lg 1815cs error code oe, will not drain, makes wierd noise during cycle
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 31, 2010 | LG WM1815CS Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
