Question about Exercise & Fitness
When the machine is switch on from the main socket and than on from the machine on /off switch, it trip the whole house fuse box.I have change the 13amp.plug fuse, I cannot locate where the machine fuse,please help.
  • Anonymous Mar 24, 2014
    running machine trips the main fuse when switched on
    Sergeant:
  • 175 Answers
Hi..It is next to the switch where you turn on.Open the
casing that stores the motor etc.Should be able to locate
it there,usually hidden inside a capsule.
check it out..
thank u..
kindly rate my response..
Posted on May 09, 2009
The machine has been working well but recently when switched on now trips the whole house safety circuit.
Try plugging something else into the outlet socket to see if that throws the trip fuse. If it does then the outlet is faulty. Try plugging the washer into another outlet and see if it throws the trip in which case the machine is suspect.
Sep 23, 2015 | Washing Machines
TRIPS FUSE IN MAIN HOUSE BOX
you may have to add a different fuse line in your box....PLEASE DONT ADD IT TO EXISTING FUSE LINE
Sep 23, 2014 | Zanussi Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
My house fuse box is fitted with a master RCD. A feed off a lounge socket goes threw the wall and feeds an external weather proof RCD box which when switched supplies my garden lights. If a garden light...
Appears the main box RCD is just as fast as the secondary RCD and it sensed the same fault that triggered the outside unit and it didn't wait around to see if that outside unit did the job.
Sep 07, 2013 | Kitchen Ranges
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
SWITCH THE POWER OFF FIRST
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Exercise & Fitness Logo
79 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
