Question about Coffee Makers & Espresso Machines
Control panel on my saeco magic comfort coffee beans empty but container is full
dutchman05
  • 487 Answers
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Posted on Apr 16, 2008
SOURCE: Saeco Italia SUP021 YR - Red light #29 on solid
Comment on oily beans - try not to use them. If you are looking for a stronger flavor coffee, an an extra shot to your drink. Oily beans cake inside the grinder, brew group + components and strains them potentiallu causing malfunctions.
Also dark beans are usually over roasted which makes the makes real coffee flavor lose. Espresso coffee beans should have very little to no oil and be unifrom in color.
Another approach if you are looking for stronger coffee flavor. use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee. Visit http://www.coffeetico.com/did_you_know.htm for some more interesting information.
Posted on Jun 20, 2008
SOURCE: Saeco magic comfort coffee machine grinder
Empty beans out. Take the two screws out.
Put bean grade to 1. Run the machine as if making coffee. Use a vacuum and clean the bean grinding machine area. Run the machine again.
Place bean container back and put screws back in. Fill bean container.
This worked for me
Posted on Aug 30, 2008
SOURCE: Need Instruction Manual for Saeco Magic Comfort Plus
http://products.saeco.com/index.asp?id_paese=7
follow the link to the instruction manual
Posted on Jan 02, 2009
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
Coffe Machine Saeco Magic Comfort
the coffee beans grinder is too fine .Turn to next number,
Oct 29, 2013 | Saeco Magic Comfort Plus Espresso Machine
Hi there, I have a saeco incanto classic manual machine (had it for 1 week). The machine says it wants more beans (red light flashing) but it is full already. I have tried to empty the bean container...
The light comes on for two reasons. One is out of beans - the other is coffee cake thing is full. Sometimes the brewing device ( that big thing inside the door) will have a bit of coffee cake in it. Just take it out ( Squeeze tab and slide out) and rinse in sink. place back in. Very common issue so get comfortable with sliding this thing out to clean
Dec 04, 2010 | Saeco Incanto Classic Espresso Machine
My machine drinds coffee in large pieces.It doesnt grind when I set the regulator on 6 or 7 and appears message "Coffee beans is empty"
HI
One possible problem is your grinder has become separated, so your beans are not feeding equally. The beans are going to one side of the burrs and are ground into big chunks. If you remove the beans in the bean hopper and look down on the grinder. If the cork screw is off to one side that is your problem. Of you can move the cork screw from side to side you need to replace your grinder in either case.
Oct 12, 2009 | Saeco Magic Comfort Plus Espresso Machine
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco italia
Apr 05, 2008 | Saeco Incanto Classic Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
