Question about Kenmore Freezers
Upright freezer door sagging
Door sags such that top left corner of the door seal is barely making contact with the primary freezer body.
jaylex
  • 417 Answers
SOURCE: freezer seal
Turn the machine on to full empty all contents and leave for about 30 minutes then try to close door if doesn't work check the seal for splits.
Thanks J
Posted on Feb 16, 2008
Illeagle
  • 525 Answers
SOURCE: Freezer door won't close at top
If you are careful, open the door 90 degrees and place your leg against the bottom corner inside of the open door and your hand at the top corner, then GENTLY push inward. You should be able to feel and see the move or twist. Then close the door to test for proper sealing. Another way to adjust the door is to loosen the screws behind the door seal and twist,but this usually unnecessary if you do the leg trick properly.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0100_34.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 20, 2008
  • 1462 Answers
SOURCE: new freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Posted on Nov 29, 2008
mumma_1
  • 903 Answers
SOURCE: how to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Posted on Dec 08, 2008
jumptrout51
  • 3361 Answers
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Posted on Mar 27, 2009
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Things don't freeze on the top shelf right hand side of the door. Also have small amount of water that drips after freezer is opened. This is a manual defrost freezer 20 cu foot freezer
I would suspect the door seal is not making contact or has some defect in it. And that defect is probably in the top right corner of the door. If you have a thermomiter, wait until the compressor kicks in and then slowly run it around the door seal. There should be some area that is colder than the rest. If I am right, then you will need to replace the seal.
Jun 15, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Door not sealing properly. Visible gap in the upper left corner. Notice ice building up near gap. How do I fix it?
dear sir,
i think your freezer,s door there is one rubber between door and body it has been turn and damaged its need to replace. after change this rubber your who is sealing your freezer,s door your ice problem will be solve.
hope answer the question
thank you
please vote!
Jul 08, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Fridge door sagged and needs adjusting.
the screw holding the door is not well tightening.
Feb 19, 2010 | Freezers
How do I change the door seal on a gibson UR freezer?
The most important thing is to make sure the new seal is warmed up to room temperature so it is soft and workable. Since the seal on mine is attached to the top door there is nothing to gain by leaving the door attached. Working upside down would leave the door open longer than just taking it off.
If you still have food in the freezer just put blankets over the top until the door is back on. If you have screws holding the seal it will go much easier. Mine has plastic pins that break easily pulling them out.
Get the edges as straight as possible to avoid leaks.
Sep 19, 2009 | Freezers
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
New freezer has bad door seal
Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Freezers Logo
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
