Question about Indesit Washing Machines
Indesit fault codes IDL40 dishwasher - Indesit Washing Machines
  • 105 Answers
SOURCE: indesit dishwasher
machine is flooded in base
means you have a leak in dishwasher
dismantle check feed pipe to top basked probable faulty feed pipe replace if so
Posted on Feb 24, 2008
SOURCE: Indesit IDL40 Dishwasher Fault
pump blocked
Posted on Jul 28, 2008
from indesit website http://www.indesit.co.uk/indesit/_pdf/manuals/19504287203_UK.pdf
Posted on May 12, 2009
SOURCE: f-02 fault code on indesit we16 washing machine
For what it is worth my WE16 often stops with an F-02 display within 3 minutes of starting, but only in summer months. Powering off and restarting usually cures it, and it will then go on to run several loads without problem. I keep the machine in my cellar boiler room, and attribute the problem to high humidity when the boiler is not running. Changing the PCB does not cure the problem, nor does protecting it against humidity (eg poly bad and silica gel). I conclude that moisture getting somewhere unexpected (tacho perhaps?) can cause this error.
Posted on Jun 12, 2010
heatman101
  • 43501 Answers
SOURCE: my indesit IDL40 slimline dishwasher keeps
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 25, 2011
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
Indesit idl40
Here is the manual
If you look at the trouble shooting page, flashing lights mean a clogged filter . If 2 flashes it needs to be turned off , and turned on again after five minutes. There is a call number -
Mar 20, 2014 | Dishwashers
Lights 1 and 2 flashing indesit IDL40
I used the solution above and my dishwasher now working!!! I would add, plenty of towels and a tray or three to catch the stinking water that comes out of the outfow when you tip it up. Yes 6 screws to remove the back, but on the Indesit IDL40 two additional longer screws in the centre are helpful to remove. Then just tuck the bit that was attached out of the way. My pump was cream and white - check out pumps online to see what they look like. Undo the one screw holding the pump in place and then you have to twist it to release three little pegs. I washed outs loads of small bits of grit. Then easy to put back together. Re-attach the drain pipe to your drain, electric plug at wall and water inflow pipe. (Check for leaks!) I am so happy! Took me two hours but I had to hunt for the info and find the hidden screwdrivers. Husband will be pleased I think.
Jan 11, 2014 | Indesit 18 in. D41 Slim-Line Free-standing...
My indesit IDL40 slimline dishwasher keeps leaking?
Leaking Dishwasher
heatman101
Sep 25, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Hi, our Indesit IDL500 dishwasher has stopped working. The fault light 2 is flashing. The manual doesn't mention what fault this indicates. Any ideas. Cheers, Neil
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
Sep 26, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
IDL40 only washes in cold water now.
YES IT SOUNDS LIKE IT'S THE ELEMENT OR MAYBE A WIRE HAS COME OFF THE ELEMENT FROM VIBRATION,
May 29, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Mar 25, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit dishwasher
Feb 23, 2008 | Dishwashers
Washing Machines Logo
26 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
