FixYa.com
Tags:
ASUS P5LD2-VM Motherboard
Incorrect power management
posted by Skumar2007 on Oct 11, 2007
I have recently purchased  ASUS P5LD2-VM motherboard. Everything is working fine except that the power management is incorrect.  The default elapse time to turn off my monitor is 20 minutes. Whenever I open my computer and work on any software, my monitor automatically turns off after 20 minutes although the application in which i am working is active. Then i have to press any key on my keyboard or move my mouse to power my monitor again.  Then again after 20 minutes the same thing happens.
Even when i watch tv on Windows Media Center the same problem persists.
Suppose I start watching tv at 10 am and i wish to pause live tv  at 10:20am, Live tv gets paused but at the same time my monitor also turns off eventhough the media center application is active.
Can anybody help me out?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 31, 2007
FixYa! (100)
Teddo
Rank:Guide Guide
Rating: 95%, 5 votes
Have you set up 'Power management' in Windows? The default is to power down the monitor after 20 minutes.
Right click on the Desktop and choose 'Properties' - Go to the 'Screensaver' tab. Look for the 'Power' button on the lower right.
You'll see the options available on the pop-up.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 11, 2007
FixYa! (100)
Beni S-P
Rank:Guru Guru
Rating: 85%, 1893 votes
Dear u have a problem with VGA or Monitor...U should try to put new vga in you'r mother board and try.If still wont work then you have a problem with monitor
Can you Help with these Motherboards problems?
Motherboards
carte mere adequat ? mon...
j'ai boitier du mdele... Answer This...
Motherboards
My camera is not working,
My LG KU990 camera is not... Answer This...
Motherboards
MSI 745 Ultra onboard power led
Hey, you gave a great answer on... Answer This...
P5LD2-VM replaced Power Supply...
now switches off right after... Answer This...
Linspire 6.0 deleted &...
I cannot get my emails and when... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
