Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
hope this helps
There are two basic ways to make a printer available to the PCs on
your home network:
Attach it directly to one computer and share it with all the
others on a network.
Connect the printer as a stand-alone device on the network
itself.
This article explains how to do both in Windows. However, you should always first consult the information that came with your
model for specific installation and setup instructions.
Setting up a shared printer
Traditionally, the most common way to make a printer available to
a home network has been to connect it to one of the PCs and then tell Windows to share it. This is called a shared printer.
The advantage of sharing a printer is that it works with any USB
printer. The downside? The host PC always has to be powered up, otherwise the
rest of the network won't be able to access the shared printer.
In previous versions of Windows,
setting up a shared printer could sometimes be tricky. But a new home networking
feature in Windows 7 called HomeGroup has
greatly simplified the process.
When a network is set up as a homegroup, printers and certain
files are automatically shared. (To learn more about what homegroups do and how
to use them, go to the Windows website and search for "HomeGroup:
Recommended links.")
If you've already set up a homegroup and want to access a shared
printer from another homegroup PC, just follow these steps: On the computer the printer is physically connected to, click the
Start button , click Control Panel, type homegroup in
the search box, and then click HomeGroup. Make sure the Printers check box is
selected. (If not, select it, and then click Save
changes.) Go to the computer you want to print from. Click to open HomeGroup. Click Install printer. If you don't already have a driver
installed for the printer, click Install driver in the
dialog box that appears. After the printer is installed, you can access it through the
Print dialog box in any program, just like a printer
that's directly connected to your computer. The computer that the printer is
connected to must be turned on to use the
printer.
To manually connect to a homegroup
printer
Setting up a network printer
Note
Network printers-devices designed to
connect directly to a computer network as a stand-alone device-were once found
mostly in large offices. No more.
Printer makers are increasingly offering inexpensive inkjet and
laser printers that are designed to serve as network printers on home networks.
Network printers have one big advantage over shared printers: they're always
available.
There are two common types of network printers: wired and
wireless.
Wired printers have an Ethernet
port, which you connect to your router
or hub
via an Ethernet cable.
Wireless printers typically connect to your home network using
Wi-Fi or Bluetooth technology.
Some printers offer both options. The instructions that came with
your model should tell you exactly how to install it. Click Add a printer. In the Add Printer wizard, click Add a network,
wireless or Bluetooth printer. In the list of available printers, select the one you want to use,
and then click Next. If prompted, install the printer driver on your computer by
clicking Install driver. If you are
prompted for an administrator password or confirmation, type the password or
provide confirmation. Complete the additional steps in the wizard, and then click Finish. Make sure that you have permission
to use these printers before adding them to the computer. You can confirm the printer is working by printing a test page.
For details, see Print a test
page
Tips
