Question about Siemens Dishwashers
The water is not hot
The dishwasher is not hot
Kitchenaid dishwasher KDC-18 works but the water does not get hot just cold. Any solution?
Dishwasher must be connected to a hot water line in order to work properly. Also, it often requires a good deal of time for hot water to make its way from the water heater to the dishwasher. If the dishwasher is located under the kitchen counter, turn on the hot water in the sink until it runs hot, then start the dishwasher.
Many dishwashers have a built in heater, but hot water should be initially fed into the dishwasher through the water inlet in order for it to perform properly.
Mar 17, 2013 | KitchenAid Dishwashers
My dishwasher has always washed in cold water never had any hot water why is that
Probably because it is hooked up wrong...
The water feeding it should be hot water... meaning it should be hooked into you hot water piping, not the cold water...
The dishwasher will keep hot water hot but it is not powerful enough to heat the cold water up...
heatman101
Jul 16, 2011 | Servis 23 in. M4306 Free-standing...
DA6141....DOES IT HEAT THE WATER? CAN ONLY SEE A HOT WATER INLET PIPE TO THE REAR....
Your dishwasher uses your hot water to wash the dishes.
Attach your hot water to both the sink and dishwasher at that (hot water) inlet.
Run the hot water in your sink until it is very hot, then turn on your dishwasher.
Jan 09, 2011 | Zanussi Dishwashers
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher is not heating the water up just running cold
Try turning on the faucet by the dishwasher and let the water run until it gets hot. Once this is done turn on the dishwasher and see if the water is warm or hot. Most dishwashers do not heat the water (residential dishwasher) they take the hot water from the hot water side of the sink. If the water heater is located a distance from the dishwasher then the cold water fills the dishwasher before the hot water can make it to the unit. This should cure your problem.
Hope this helped
Dave
Jan 15, 2010 | Dishwashers
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
AEH Favorit 50730 dishwasher seems to work fine other than the water never gets hot. Is it easy to replace the heating element or whatever that could be faulty?
If this dishwasher is a residential dishwasher the water that is supplied to the unit is from the hot water side of the sink supply. The dishwasher does not heat the water it uses water from the water heater that is connected to the house. It sounds as if the dishwasher is hooked up to the cold water supply instead of the hot water supply. The heating element you see in the dishwasher is for drying purposes and not for heating water. I would check the hot water supply for your dishwasher to see if that could be the problem. Also remember unless you have a recirculating pump on the hot water there will be an amount of water in the pipe from the water heater and the dishwasher that has sat and cooled down over a period of time therefore when you turn on the dishwasher you will not get hot water immediately due to the distance the dishwasher is from the water heater. You will notice when you turn on the hot water to thew sink you do not get hot water right away you let it run for a minute before it gets hot since the dishwasher is connected to the same valve as your hot water to the sink it acts the same way.
Good luck on your repairs hope this helped.
Dave
Sep 02, 2009 | AEG 24 in. Favorit 50730W Free-standing...
My dishwasher is filling up with water but the water want get hot
The water needs to be hot before it goes into the dishwasher. Just before you start the machine, run the hot water faucet until the water gets hot.
Some dishwashers have a heat boost feature to sanitize the dishes, but it's not intended to take cold input water and make it hot.
Nov 12, 2008 | Dishwashers
Hot water for dishwasher
Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
Oct 06, 2008 | Dishwashers
Dishwashers Logo
69 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
