Question about Hotpoint Aquarius WF210 Front Load Washer
Machine will not drain water or spin
My machine will not spin or empty water even after I used a jug to empty water from drum it will still not spin.
    Sergeant:
  • 175 Answers
Hi..Most washing machine have a drain filter that can become
clogged over time.Front load washers typically have a small
removable panel about the size of a half sheet of paper on the
bottom front of the machine.the filter is inside.
check it out..
thank u..
kindly rate my response..
Posted on May 09, 2009
    Sergeant:
  • 197 Answers
Check the following
If you have a pump out programme on your dial - try that ,if it pumps out water ok it then could be the motor brushes.
If it does'nt pump out, then the pump could be blocked or faulty.
Take off washer top and un-clip brushes out with a small flat head screwdriver from the motor and check to see if they are worn. If the brushes are dull and short in length, then its time to change
Old Hotpoint machines often need replacement brushes. They can still work to agree but not spin or punp out water.(under load)
Good look!
Posted on May 17, 2009
FISHER AND PAYKEL MAKING NOISE BUT WILL NOT RINSE OR SPIN, AND NO WATER PUMP OUT
Blockage in drain pump. You will have to empty water out with a jug. Then get machine outside and remove drain pump so last of water comes out. Check for any rubbish in pump, then put pump back and test it.
May 10, 2018 | Fisher and Paykel Washing Machines
WHY ON MY MAYTAG EPIC WHEN IT GETS TO SPIN IT JUST MAKES DRAINING NOISE AND WATER WONT DRAIN?
Sounds like your drain line is clogged. You may also have stuff clogging a water filter just before the pump, or the water outlet coming from the drum.
It could also be a problem with the pump, but until the drain line is opened up, you still won't be able to empty the water from the washer.
Aug 11, 2014 | Maytag EPIC MFW9700S Front Load Washer
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Water Accumulating in Washing Machine Drum
Could be draining from your sink outlet. Ensure the outlet pipe is routed higher than the sink trap. Normally attached underside of the work surface.
Mar 04, 2018 | Hoover Washing Machines
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Hotpoint Aquarius WF210 Front Load Washer Logo
345 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
