Question about Fujitsu fi-6770 Flatbed Scanner
Blue background white - Fujitsu fi-6770 Flatbed Scanner
White background turn blue eos7d
Unfortunately, I'd have to say that there's something wrong with the camera. The blue channel is going too high (or the red and green channels are too low). Take it in to a service shop and have them look at it.
Sorry.
Feb 04, 2012 | Canon EOS 7D Digital Camera
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
The background is blue. how can I turn it white?
Could be a cable problem if not it's a failed lcd
Aug 31, 2009 | Epson Office Equipment & Supplies
Display background color
Check your MS Windows System colors
Most likely that is the cause of the problem.
Sep 29, 2008 | Corel WordPerfect Office 12 Standard...
DOES NOT PRINT IN BLACK
This may sound a bit dumb, but believe me as a tech support specialist, I have seen it happen. If you are trying to print a document, what color do you have set for text? I had a lady who wanted the text to be white on blue on the screen in Word and instead of setting it with a blue background and "auto" text, she set the text as white. White print on a white background (paper) doesn't show up...:-)
May 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Jun 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Fujitsu fi-6770 Flatbed Scanner Logo
20 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
