Question about 3M Office Equipment & Supplies
Projector keeps shutting off
I start my 3M Digital Media System-projector, and for a couple of seconds, the screen appears as it should. Then it switches to black, but doesn't turn off. I recently replaced the lamp. Any ideas?
SOURCE: No Light from projector (worked previously)
theres prob something wrong wif the bulb
Posted on Dec 20, 2007
SOURCE: Shutting down after 2 min
call panasonic-- they have extended the warranty on this issue up to 18 months, as it is a known problem with the sealant for the iris. If the sealant is not moving, the iris sticks and the projector goes into lockdown. Call this number and they will take care of your problem: 1-800-211-PANA (7262)
Posted on Oct 24, 2008
  • 3 Answers
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: Projector problems
Hello!
Hope this can help.
projdoc
  • 2237 Answers
SOURCE: my 3m s20 projector has a big yellow spot
the polarizer on the blue lcd panel is fried due to excessive dust and heat. you may have to replace the whole optical engine.
Posted on Jan 27, 2010
Please forward the details how to fix hour settings in the system when the time to lamp replacement in 8785 model of 3M.
hi,
.To display the total lamp hours, press and hold for 3 seconds, the Reset button on the projector or
Timer button on the remote control.
.To reset the lamp timer, press the Reset button on the projector or Menu On button on the remote
while the total lamp hours are displayed. Use the arrow button on the projector to
select 0 (or CANCEL).
ok
Mar 08, 2011 | 3M (78-6969-8778-9) Projector Lamp for...
I cant connect my acer laptop 1640 to 3M DIGITAL PROJECTORS...
you need to check a couple of things. First on projector, check input settings it should be PC/computer etc. Then check aspect ratio settings on your PC to make sure it's compatible with projector.
Jan 07, 2011 | Acer Aspire 1640Z Notebook
When I plu-in the VGA cable my screen goes blank on my HP-1170. I then have to reboot to fix video on laptop. Done all the resolutions and I cant seem to get the external projector to show anything other...
reset the settings to factory default through the menu. swap out the cable. depending on your laptop, press function-f4 or function-f7. if still nothing, you may have a main board issue.
Dec 27, 2009 | 3M MPro110 Micro Professional Digital...
How do I change the bulb for the 3msystem 800 projector
there is a door with one screw on the side of the projector head. loosen the screw and remove the door. loosen the screw at the base of the lamp and remove the lamp by the handle. replace with a good lamp and tighten the lamp screw. replace door.
Sep 02, 2009 | 3M Digital Media System 800 Projector
Dms700 projector 3M problem
cannot handle digital signals, only analog.
Aug 22, 2009 | 3M DMS700 DLP Projector
Lamp time
Hi
You will have to reset the lamp timer as follows :
Hold down the up arrow key on your projector for a couple of seconds - projector must be switched on.
You'll see a on screen message appear in one of the top corners on the image....then just follow the two basic steps as requested on screen.....your lamp timer will now be reset.
Then shut down the projector and restart for changes to take effect.
Oct 25, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Info
Hi, the M3 6400 doesn't have a lamp; it is an overhead projector (dynamic) display which needs an external light source. When you start it en put a ordinary lamp behind it and after connected it to a 'source' (computor...video) you will see images appear.
Aug 21, 2008 | 3M Projection Panel 6400 Multimedia...
3M MP8725B Projector
apply any video signal from video in(yellow jack and yellow socket)if it is ok-change your vga cable-and confirm that input in pc mode.if no signal appear from video in also you must contact a good service center.
Jul 04, 2008 | 3M Office Equipment & Supplies
19 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
