Hello. Might be that there is no Recovery installed on ur device and surely you can't enter the recovery mode.
first make sure that the Vol -/+ key are really functionable and besides be aware for some tricky when you might recognize the Vol + key needs a little extra pressure for clearly circuit! Maybe, Maybe
You have to try! look out for a flashable recovery for your device and flash it with Odin! I pray you don't use KIES!!! is really easy, u'll quickly find a manual for that via "google". Just to make sure a recovery is present on the Ace. by know hitting the key-combi remind you for keeping the "Power" and "Home" Button pressed until the second Logo appears. The other way could be release the Vol+ key by appear of the first Logo and keep hitting it over to second Logo appear. Sadly it might be keep the Vol+ Button released after first Logo could do the Trick! So...... good luck on give these methods a try!
adb rebooot recovery using pc-connection or "su reboot recovery" on terminal app might be also work for You!
have fun!no pain, no gain *smile
1. If your mobile is on, power it off. 2. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power). You will see the word Start with an arrow drawn around it. 3. Press Volume Down twice to designate Recovery mode. 4. Press Power to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark. 5. While holding down Power, press Volume Up. 6. Use the volume keys to scroll to "wipe data/ factory reset" and press Power to select it. 7. Scroll down to "Yes - erase all user data" and press Power to select it.
