Question about ASUS ZENBOOK UX32A-DB51 13.3" LED Ultrabook - Intel Core i5 i5-3317U 1.70 GHz - Silver Aluminum - 1366 x 768 HD Display - 4 GB RAM - 24 GB SSD - 500 GB HHD - Intel HD 4000 Graphics Card - Bluetooth - Webcam - Genuine Windows 7 Home Premium - HDMI 88622724
Magnetic lid switch - ASUS ZENBOOK UX32A-DB51 13.3" LED Ultrabook - Intel Core i5 i5-3317U 1.70 GHz - Silver Aluminum - 1366 x 768 HD Display - 4 GB RAM - 24 GB SSD - 500 GB HHD - Intel HD 4000 Graphics Card - Bluetooth - Webcam - Genuine Windows 7 Home Premium - HDMI 88622724
Bypass LG WF-T9250PP lid switch
Before bypassing the lid switch, check whether the magnet on the lid is OK. The reed switch is under the cover adjacent to the position of the magnet when the lid is closed.
Jun 09, 2015 | LG Washing Machines
My ge spacemakermodelwslp1100d0ww reads lo when i try to start it
Hello Tina,
The LO code means lid open so the washer thinks the lid is open and wont agitate/spin with the lid open. What to check and see if the lid switch which is basically a magnet is good firstly check on the lid for the magnet to be in place,with the lid open the magnet will be in the upper left corner (ya can check it by seeing if a paper clip or similar item sticks to the magnet) if it seems ok next check where it would fit to when the lid is closed which would be on the top in the front left corner and check and see if that area seems intact and not cracked. If ya find the magnet or the area on the top to be in good shape the lid switch would need to be replaced . The part number for that switch is WH12X10104 the exact name for it is the REED SWITCH and it could be purchased at your local appliance parts store or online at;searspartsdirect.comapdepot.compartselect.comapwagner.comrepairclinic.com
I hope i have been able to help ya fix your washer,GENE
Oct 04, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Screen won't come on when laptop powers on
1. Software
- Try Fn + F5 or something like that
2. Electrical
- Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
3. Magnetic On/Off Switch to detect of Close/Open Lid
- Your magnet switch is fubar some how. Open up the speaker cover and see if your lid actuator switch that come in contact with the magnet on your lid cover is stuck or not (find where the magnet is in the back of the front lid cover, trace where the magnet area actually touches the base of the computer and you will find the switch)
- Workaround, start windows with lid at 30 degree angle
Toll Free: 877 407 9229
any doubts you can get in touch with the best pc doctor through
www.thebestpcdoctor.com
Oct 01, 2011 | Compaq Presario CQ60-220US PC Laptop
Washer would wash, or spin. the water appears to drain ok and fills ok
the magnetic lid switch is bad,its located underneath the lid toward the right side of where the lid lays,yoiu will see the magnet under the lid,the switch is below this
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
Verex stepnote, laptop is on, can see the screen in the background" -
So there are many problems which will cause issues of the screen.
1. Software
2. Electrical
4. Hardware
- You need to replace either Inverter, Blacklight, or everything.
Jun 19, 2011 | Everex StepNote NC1500 Notebook
Power of laptop is on but nothing is happening
1. Software
2. Electrical
4. Hardware
- You need to replace either Inverter, Blacklight, or everything. =)
Good luck and have fun!!!
Jul 26, 2010 | Compaq Armada M700 Notebook
Whirlpool stack washer will fill but will not progress to rest of cycle
It sounds like the lid switch is not making contact. It is a magnet located on the lid so that when you close the lid, the magnet pulls the switch closed. Make sure the magnet is still on the lid. If you washer lid will not stay open on most models, the magnet is gone because this is the same magnet that pulls the lid switch closed. If you can find where it goes, find a strong magnet and place it on the top inside rim where the lid goes when closed. Turn the machine on, let fill with water. Once this is complete and the machine should start. Take the magnet and move it around the rim until the unit starts running. If you can't get it to run, most likely the switch it's self is bad. I think you will find the magnet on the lid is gone and the machine will start running once you pass a magnet over the place where it goes. If so you will need to replace the part.
Oct 17, 2009 | Whirlpool LTE5243D Top Load Stacked...
Reads "OP" when lid is closed
Magnetic reed switch on left side below the gray rubber bumper, shown here...
http://www.repairclinic.com/SSPartDetail.aspx?PartID=1033130&PPStack=1
Release two spring clips in front between main top and front panel using putty knife. Lift the main top and access the left and right door locks here.
To access and see if the magnet is in place, remove the dispenser from lid.
Gently pry the bottom of the plastic inner lid toward you then down. This will let you see if the magnet is in place on the right front corner of the inner lid.
http://fixitnow.com/wp-content/uploads/2006/09/washer_switch.JPG
Seems to be a common problem with this washer. Apparently, the lid isn’t completely watertight and allows water to get into this switch corroding the contacts and the wires.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 09, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Have the OP signal, have cleaned all latches and lid areas but still not working. how do i pop off the top portion to check the side locking latches? i can see they are not well sealed and would rather fix...
This is a common problem on this washer. (The OP fault code). It is caused by a faulty magnetic reed switch. Apparently, the lid on these washers isn't completely watertight and allows water/moisture to get into the switch and corrode the wires and connections.
The switch is on the left side under the rubber bumper, Release two spring clips in the front between main top and front panel using a putty knife. Lift the top. To access and see if the magnet is in place, remove the dispenser from lid. Gently pry the bottom of the plastic inner lid toward you and down. This will let you see if the magnet is in place on the right front corner of the inner lid. Here is a picture of a bad door lock switch:
Sure hope this helped and best wishes.
Jul 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
No spin
lid switch sounds like some ge had a plunger type switch operation ck for broken pin on lid that pushes switch lever down ..others had a magnetic type switch magnet on lid front right corner that closed switch on cabinet front corner
Jul 31, 2008 | GE WBSR3140DW Top Load Washer
ASUS ZENBOOK UX32A-DB51 13.3" LED Ultrabook - Intel Core i5 i5-3317U 1.70 GHz - Silver Aluminum - 1366 x 768 HD Display - 4 GB RAM - 24 GB SSD - 500 GB HHD - Intel HD 4000 Graphics Card - Bluetooth - Webcam - Genuine Windows 7 Home Premium - HDMI 88622724 Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
