Question about Acer Aspire 7110-2069 Notebook
Problem with sound card when using skype
When using skype, there is no sound and get message problem with sound card
When on skype this message comes up Can't access your sound card skype needs to access your computer sound card to make calls
check your sound drivers from device manager, if not installed, then install updated drivers of your soud device and then it will not show any problem
Jan 11, 2013 | Computers & Internet
My sound card not plugged in been moveing furniture around what wires do i plug in
I am assuming you are using desktop PC. The sound card is where the speakers are connected to. If your computer can't recognize it, open your CPU (while OFF) remove the soundcard (if it is not integrated to your MoBo) then replace it back.
Sep 16, 2011 | Skype IM
I cannot run skype calls on my Lenovo L420 laptop.. I get a message: Skype cannot access your sound card.
You could try to select the correct sound card from Skype option menu from the dropdown menu.
You may also want to check that the sound card is correctly installed in your system
Aug 22, 2011 | Computers & Internet
People can hear me but I can't hear them
Does your sound card work? Did you run the sound test in SKYPE? In the options section, click on Sound Devices and select Make a Test sound. If that works, click on Make a test call.
Good Luck, Jim
Feb 22, 2011 | Skype IM
On SKYPE the other party cannot hear me. A message comes "SKYPE needs to access your sound card" what is the problem?
The problem is that your sound card drivers are not installed properly.
Try to re-install your audio drivers using the driver cd, they provided to you and from the compaq website.
Jul 18, 2010 | Compaq Presario M2000 Notebook
My lap top is telling me I don't have any audio devices
if sound is working on laptop but not on skype, then the settings in skype needs to be set to you audio. go in to skype setting and audio and click on your audio and make it default, same for the mic choose the one you have and make it default. and click on save or ok when done.
Jul 04, 2017 | SMC Realtec Network Card NERENC01
My voice is mute when calling friends on skype -
Make sure you don't have your sound card muted on your computer.
Nov 14, 2009 | Skype IM
Skype conversations have been perfect for years until today when my microphone went silent. Replacing with a new micro made no difference. Test is silent. I can't hear my voice at Skype sound test service....
chek on skype > tools > option > try to change the mixer there
if not and you cannot make any sound from your mic to any other program you shoud think maby something hapaaned to the sound card
daniel
http://rylwy.com/
Jun 12, 2009 | Skype IM
No sound alert on incoming messages in Skype 4
Here is my experience. This drove me nuts for a while but it works now.
I had the same problem with 4.0.0.206. I played around with mute/enable in Options/sound and Options/audio settings. I changed to ringing to my laptop speakers and now it all works. Go figure.
Feb 11, 2009 | Skype IM
MY WEBCAM RE USED ON 'SKYPE' HAS WORKED PERFECT FOR A MONTH OR SO NOW WHEN I TRY TO CONTACT (re little green phone on skyp menu" or when others try to get me a message comes up and says; :problem with...
A sound card is a device inside a computer which regulates the input and output of audio to the computer. They can be a separate "card" or piece of hardware, or they can be integrated on your motherboard.
A problem with your sound card could be a multitude of things. The first step of solving the issue would be to verify that your sound card has the most recent drivers, or updates, for use. Find out what sound card you have by going to Control Panel, then Performance and Maintenance, and click on See basic information about your computer. A panel will open up, and click the tab at the top which says Hardware, and then click the Device Manager button. Scroll down to Sound, video, and game controllers, and double click that (or press the + next to it) to open up the drivers and codecs for sound and video. Anything relating to the sound or audio may be it. Then, search for the company of your sound card and find the appropriate drivers.
Jan 22, 2009 | Skype IM
Acer Aspire 7110-2069 Notebook Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
