Question about Android Apps
Whats wrong The lights and car are shut off but the back windw light stays on and also the right back light stays on. I went to move rear light wire and I heard like a motor sound of some sort
  • 4,340 Answers
Your brake light switch is suspect. What is happening is your left brake light is burned out. These lights may have been on for a while, replace them all and have no worries. BUT, I suggest replacing or correctly adjusting the brake light switch, near the brake pedal. The brake lights work at all times, regardless of ignition setting, including off.
Easy and inexpensive issue that you have. Lucky.
Posted on Nov 29, 2013
2013 jeep wrangler battery went dead charged it not it wont stay running with the key runs for about 15 sec will shut off with the key but only way i can start it is with the after market starter.
ok is real jeep and fake remote, 2013 is not 2103
ok
remove this junk from car, and magic happens you can drive it.
I can see its installed wrong too.
Jan 30, 2017 | 2013 Jeep Wrangler
We turned our tv off for like 3 hours went to turn back on and red light turned blue like it was going turn on but screen stayed black then speaker made a noise and light went back to red. It did that 28...
The problem is the power supply of your television.The power supply have abnormal voltage supply output cause of leaked capacitor.The leak capacitor have bulging tops, so that you can identify the leak capacitor. Just remove the cover and find the power supply and replace new capacitor with same polarity.Hope it will help you.Thanks..
Sep 04, 2011 | Polaroid TLA-04011C 40 in. LCD TV
I recently changed out the drums on a used 88 pickup I purchased for my son and now the brake light on the dash cluster stays on as well as the rear brakes lights stay on. I adjusted the rear drums to...
stop light switch you have adjusted the brakes correctly and noy the pedal has come up hard so reset the stop light switch ,also make sure handbrake is going right down as some vehicles have a switch on their as well and i have never seen one of these cars in europe so i honestly cannot tell you model problems only whats wrong
Oct 09, 2010 | 1988 Chevrolet Silverado 2500
How to get off the ABS light, I know than is possible conecting to ground the line ''L'' in the DLC but no have information witch one is it. Kia Sedona 2004
Your problem is that something is wrong, even if you get the light reset it will come right back on once the car is moved, you need to scan the abs computer and get the codes, these codes will tell you whats not working then you check it out, it may be a bad wheel sensor or may just be low brake fluid but you wont be able to just shut it off, once the problem is fixxed all you have to do is drive the car down the road and the light will shut off when the computer sees everything is working correctly, hope this helps,
Apr 21, 2010 | 2004 Kia Sedona
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Engine light is on, car wont stay on
check the fuses , you can have a o2 sensor fuse open, also check the wiring because o2s are close to the cats or manifoldss some time they burn and get shorted.., other thing you can do is unplug the o2s and drive it like that and see if it shuts off , if it doesn't so the problem is around that sensor...hope this help..
Aug 03, 2009 | 1999 Dodge Intrepid
The volt light came on 1992 lesabre whats wrong
You need your alternator replaced. It is not charging anymore.
Jun 11, 2009 | 1992 Buick LeSabre
My gauges and heat dont work on my car and the check engine light comes on
try to replace the ignition switch mine went bad and either things didnt come on or all the dash lights would stay on
Nov 17, 2008 | 1996 Chrysler Concorde
Android Apps Logo
707 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
