Question about HP Business Notebook NX9110 Notebook
No Lights On But Fans On
I have nx9110 notebook and it was turning off by it self during my work from previous 6 days. But at this time when it turned off and as I turned on to go into its BIOS when I press its del key it again turned off and when I turned it on again it gave me no display its power light and hard disk activity light turned on but after few moments all of its lights turned off but fans were working and they were on.
Now the problem is that there is nothing on its LCD no picture is available on it and no light is on even its power button light is remains off as I turned it on and its fans starts working. Some times when I turn it On Caps Lock light and Num lock lights starts blinking simultaneously and after few seconds they turned off.
please help me in this problem. I need my notebook display back.
  • Richhulme Apr 17, 2008
    Have exactly the same problem and one is for sale on ebay with what looks like the same fault. The laptop just shuts down like a power failure not a physical shutdown of windows but complete faliure like removing the battery when not on mains.
    Novelist:
  • 188 Answers
I would start by using only 1 stick of RAM this sounds like symptom of a failing ram card or occasionally ram socket. The RAM is on the bottom of the laptop under the middle panel.
If you have 2 chips try each chip individually in each socket.
If it was turning itself off it was probably overheating - i see the fans gets clogged on this series all the time. You may want to blow it out with a can of compressed air.
Let us know if you need more help.
Posted on Dec 21, 2007
Should my 2012 chrysler 200 convertible have running lights during the day time. I am thinking that they use to and now they dont work
Is your parking brake on.
to turn off your daytime running lights on your island you put your mergency break on check to see if your emergency brake switch is bad or your emergency brake is on.
Dec 12, 2014 | 2012 Chrysler 200 Touring Convertible 2.4L...
My computer wont boot up the fan and light turn on for a second then goes right off....
With the little bit of information presented, it appears that this is possible a power supply problem. One thing you can try is to unplug the power adapter from the laptop, remove the battery, then plug the power adapter back into the laptop. Then try to turn it on. If everything comes up normally, then the problem points, potentially, to the battery.
Hope this helps!
Feb 18, 2010 | HP Pavilion dv9000z Notebook
Fan shuts off on computer startup, led lights are
The fans are USUALLY controlled by the processor chip reading its internal temp and running fans as needed. Under the varying load during boot, it is not uncommon to have fans starting and stopping..
Nov 30, 2009 | HP Pavilion dv6000z Notebook
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
HP compaq nx9110 BIOS battery/hd not detected
Hi there , if the main battery is removed the cmos battery will go flat , if its a small pcb mounted 1 you can short the contacts for a short time , if the cdrom is working it mains the 5volt supply is ok and you should be able to hear the hard drive spin up unless there is damage to the pins on the hdd or the adaptor or hdd is mounted wrong .
Aug 10, 2008 | HP Compaq Business NX9110 Notebook
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Where is the CMOS location in nx9110 hp
F10 is the correct button to press when booting.
Dec 24, 2007 | HP Business Notebook NX9110 Notebook
Compaq NX9110 problem
Is the system set to hibernate? If so I would disable that function. Is it exactly 30 minutes or just a rough guess? Also check and see if there is an issue with StandBy.
Nov 18, 2007 | HP Compaq Business NX9110 Notebook
No light is on but fans on
I would bet your system has been overheating - that's why it kept shutting off. Now it may have overheated and killed your CPU or mainboard. These laptops require quite a bit of disassembly to get at the CPU. You will probably have to take it to a repair shop for further work.
Oct 06, 2007 | HP Business Notebook NX9110 Notebook
HP Business Notebook NX9110 Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
