Question about Frigidaire AGQ6000ES Gas Dryer
My frig. agq600fs gas dryer drum will not turn.
Smelled like burning last time i tried it. was working fine, opened door to check, and wouldn't work upon door closing. drum turns normally, by hand, so I don't think it's the belt.
    New Friend:
    Problem Solver:
  • 19 Answers
Good bet it's the motor!
Disconnect electric plug.
Have to get access to back of the dryer, remove a few screws.
Look at motor and belt, motors sometimes over heat - Burn Up.
Motor could be replaced, depending on the age and how long you have had it!
Posted on Nov 29, 2013
TheMobilian
  • 8220 Answers
SOURCE: Fridgidaire Gas Dryer - Mod.#FDG
Your glides are brobably broken and missing. This will make the drum hard to turn and bind the motor. Get the front off the dryer:
7411f19.jpgStart by popping the top with a putty knife.
Get the screws out that hold the front on and take a look:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
  • 142 Answers
SOURCE: My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Posted on Jan 25, 2009
  • 14 Answers
SOURCE: Frigidaire Gas Dryer - Heats for 1-2 minutes then gas shuts off
Most of the time, the culprit is a bad gas valve coil(s). Replace those, and your dryer should return to normal operation.
  • 21 Answers
SOURCE: The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Posted on Feb 20, 2010
  • 2699 Answers
SOURCE: the timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Posted on Mar 12, 2010
Testimonial: "I've already located and ordered a new timer. Thanks for the quick response."
Burning smell
Sounds like the motor has gone. If this is the case, its time for a new one.
Dec 27, 2013 | Indesit IS70C Electric Dryer
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Frig. gas dryer agq6000es not tumbling
Do you hear the motor running? With door closed.
Most dryers will spin though a little hard to do so. If it spins VERY easy the belt is possibly broken.
If the dryer is several years old it Could be the belt.
Also check for a switch for the door, if there is one.
Door switch would shut off dryer when opened.
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Won't Spin Drum
The problem could be a list of things . Let's start checking the belt , it coul be that the belt is broken or something is keeping it from doing its job ( a piece of clothing coul be stuck) due to the burned rubber smell you detected. It coul also be the electrical door switch and After checking the three first steps then comes the motor part lets hope is not . Good luck
Nov 20, 2013 | Maytag Centennial Series MEDC300XW
Dryer is making a grinding noise when the drum turns
hi your belt is ready to give up take does it smell of burning if not it soon will take the name make and model to comet they will sort you another and they are very easy to replace you just open the back of your dryer make sure it is unpluged first take the old one off and just slide the new one straight on problem sorted
Apr 26, 2010 | Maytag SDG3606A Gas Dryer
My dryer flew off of a dolly when loading it on a trailer to move it. It smells like rubber is burning when I turn the dryer on. It was working fine until we moved the dryer. Could it be the belt is loose?
If the dryer fell some distance, the drum is probably out of alignment.
If the drum is not spinning at all, something has jammed the drum and the belt is being overheated by the motor pulley.
If the drum is spinning and there is a rubber smell, the drum has been knocked off of its rollers and/or glides.
In either case, the dryer needs to be opened. Click the link below:
http://www.applianceaid.com/may-apart.html
There are two basic types of Maytag dryers, older models and the newer ones with the door that wraps over the top ('L' shaped door).
Apr 07, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Kenmore gas dryer won't turn
It sounds like the belt is stretched or slipping. The belt needs to be replaced. It has been a few years, but dryer cabinets haven't changed that much.First, unplug the dryer from the electical outlet. If the lint filter slides out the top, then remove the two screws that you see in that top door. Pop the two front clips and open the top like a clamshell. You should be able to see where the belt goes around the drum. The front is held on by a couple of bolts at the top of each side. If you remove them the front will swing out, but be careful with the door switch wires. Before removing the old belt, pay attention how it goes around the motor tension pulleys. Slide the old belt off and slide the new one on. Reassemble. I hope this helps
Mar 28, 2010 | Kenmore Dryers
Maytag electric dryer. LDE9314ACE Drum won't turn, but sometimes will. Had friend turn drum manually while I pressed start/door buttons. Drum turned fine but when I let go of buttons to shut door, dryer...
The motor capacitor is burned. You can replace it yourself. It's on the motor. Take it down to a motor shop and they will have a new one. (electric motor repair shop)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Dryers
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Dryer does not tumble, but heats up
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
if this helps please vote me a fix ya
Jul 15, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
46 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
