Question about Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range
Can ceramic glass for stovetop be refinished?
I have a small Gemco coffee pot with no directions. It says "do not use on stovetop",but does not say micro on it either. How do I use it? Pls. help.
I can't answer your question but clearly if there is any metal in the construction of the coffee pot it should not be heated in the microwave oven.
Ceramic coffee pots aren't intended to be heated in order to make the coffee. The coffee is either made in them by adding hot water or made in another utensil and poured into the coffee pot for serving and perhaps kept on a gentle hotplate in the meanwhile. Glass coffee pots are treated in a similar way.
Metal coffee pots and jugs can be used on the stovetop even though it isn't a good idea except for "cowboy coffee" when dry ground coffee is scorched in the jug before pouring on boiling water; steel is best for this.
I have used all manner of glass, ceramic and metal coffee pots and jugs on the stovetop but always using a heat diffuser - two layers of perforated steel with an airspace in between.
A coffee maker is a different thing and must be heated fairly vigorously. I find an old electric percolator is still the superior method of making coffee.
Oct 24, 2016 | Coffee Makers & Espresso Machines
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
I have a scratch on the top of my ceramic stovetop. How can I repair it?
Instructions for repairing scratches on ceramic cooktop
Things You'll Need:
  • Nonabrasive cleaner
  • Dishwashing liquid
  • Cloth
  • Razor scraper
  • Ceramic crème
  • Sponge or cloth(s)
  1. 1 Clean the cooktop with a nonabrasive cleaner, such as a glass cleaner or warm water mixed with a few drops of dishwashing liquid. Wipe with a clean, soft cloth.
  2. 2 Use your fingernail or the flat edge of a razor scraper to remove any raised surfaces on the scratch.
  3. 3 Apply a ceramic repair crème, available at most hardware or home repair stores, to the scratched area. Work in gently with a soft cloth or sponge.
  4. 4 Allow the crème to sit for 15 to 20 minutes. Wipe away with a clean, damp, soft cloth.
  5. 5 Repeat as necessary until the scratch is no longer visible.
Nov 10, 2010 | KitchenAid Microwave Ovens
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Stovetop ceramic burner turned black and smooth
Do you have a proper ceramic top scraper ?, if not buy one (about £10 UK)
Get a bottle of cream cleanser and a plastic type pan scrubber
Soak the area with warm water , pour on some cream cleanser and work it in with the scrubber , when you have formed a nice creamy froth use the scraper to get underneath the scorching
It is a lot of hard work but it does come off
Sep 28, 2009 | GE Kitchen Ranges
How do i remove scratches in the stovetop?
3M 7447 pads get at au5to parts store or more aggressive 180 grit sandpaper going with the grain of course. For daily cleaning use DeBruce Polish, it is non-toxic and odorless. DeBruce polish is also non-abrasive, also use DeBruce Polish on glass/ceramic cook tops. We get DeBruce Polish at debrucepolish.com
Aug 30, 2009 | LG LRE30755 Electric Kitchen Range
Soup boiked over on stove top
I had some luck removing food and other stains with the new Vielda Glass Ceramic Scrung (its a sponge)
"Special scour sponge for cleaning glass ceramic cook tops without scratching. Eliminates burnt-in stains and greasy dirt film. Removes grease and loose dirt particles. Microfibre side will create a streak free finish."
I found mine at Walmart. It was a little pricey but if you just use the sponge for the stovetop then it will last a very long time.
Hope this helps.
Dec 17, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
SMOOTH COOKTOP DISCOLORATION
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Aug 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range Logo
353 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
