Question about Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free Usb Prog Cable Software Cd Free
Will not transmit to a repeater
No matter how I program my radio, I cannot get the repeater. what do I do?
  • 38 Answers
1) are you within range,?
2) is there an obstruction between you and the repeater?
3) do you have the proper PL tome programmed for the repeater?
4) When you press transmit, is the correct input frequency displayed?
Posted on Nov 29, 2013
How to change bands. The radio won't go below 220.00MHz. I want to go to Hit my repeater at 147.120MHz ? HELP
your repeater transmits at 147.120,your radio transmits on a different frequency to the reapeater otherwise you would repeat right from the radio,you need to program your radio and repeater together,try a baofung radio and vertex 100 repeater,i have them and they work good,the radio is 30 bucks on ebay
Jul 13, 2015 | Universal Professional TYT TH-9000 VHF...
My Yaesu Ft-857 transmits ok on 2 meter. But the receive only work sometime?
Sounds like a bad receiver in the radio.
Have you checked the VSWR of you antenna system?
Did it ever work with the current setup?
If so has anything changed with the programming of the radio or the antenna system?
Does 70cm work OK?
Are you sure menu item 080 is set to "SQL" and not "RF-GAIN"?
Are you sure the receiver is not programmed for tone squelch?
Either of those settings could cause receive problems if not used properly.
Sep 26, 2014 | Yaesu FT-857D transceiver
Baofeng UV5 RA WILL NOT TRANSMIT IN 146 MHZ or 440 mhz bands
It's not programmed right. You can probably find more intelligible programming instructions on Google. Their manuals are not great.
Jul 21, 2013 | Radio Communications
I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Sep 13, 2012 | Generic Walkie Talkie BAOFENG BF-888s Two...
Yaesu ftm-10e squelch problem
The FTM-10E is the european version of the dual band amateur radio capable of transmitting in the amateur VHF & UHF (144Mhz & 440Mhz ) bands, that is equal to the FTM-10R sold in the US.
Many repeaters require a predetermined sub-audible tone or signal to be sent when transmitting. If several repeaters in the area operate on the same frequency, they would all transmit at the same time unless they all have different sub-audible tones. These tones allow the user to select which repeater on the same frequency will be used. The tones are either CTCSS or DCS type. CTCSS is "continuous tone coded squelch system" and DCS is "digital coded squelch". CTCSS is expressed as a frequency in Hertz and DCS is a code expressed as a number. CTCSS is more popular, since it has been around longer. When programming or tuning the radio, you will need to provide the repeater's output frequency (and the input frequency if the shift direction and amount isn't programmed - often a 600 hertz shift either up or down depending on isn't already programmed is a default value depending on the repeater output frequency) and whether or not the repeater requires a tone. If it does require a tone (most do), you will need to know the type (CTCSS or DCS) and the value (frequency for CTCSS or code number for DCS) in order for your transmitter to open the repeater and cause it to repeat your transmission AND open the squelch on the radio's receiver so that you can hear replies to your call and other conversations. Repeater directories (both printed and online) will provide all the information needed to access a public repeater, including geographical location, input & output frequencies, squelch type and values to name a few.
If you do not have the correct CTCSS or DCS set, you will see the signal meter on the radio indicate traffic - but you will not hear anything because the radio is squelched. Check the manual page 40 for information on how to program the squelch, and page 42 describes the "shift" I mentioned above. Page 64 & 65 details the theory of squelch via CTCSS and DCS and will help you understand it better.
Basically, you have a "standard" squelch - the knob on the radio and a second squelch that is either CTCSS or DCS. Both types must be set to hear anything. Not having the CTCSS or DCS set will prevent your signal from being repeated by the repeater.
If you have more question, please add them in a comment. I hope this helps & good luck!
Jun 17, 2012 | Yaesu FTM-10R VHF/UHF Mobile Dual-Band...
How many watts do midland walkie talkie xt20 have?
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
Jun 16, 2012 | Midland XT20 Two Way Radio
If i want to use a repeater station what channel do both us need to be on eg if i am on 1 does the other person has to be on 31
Your radio needs to be programmed for one channel to duplex. Duplexing is when a channel has a different frequency for transmit than for receive. (Not all radios are capable of doing this.)
A repeater listens on one frequency and then retransmits what it hears on another frequency. See your local radio dealer for more info, and to see if your radio is repeater capable.
Oct 13, 2009 | Motorola UHF 435-470Mhz Antenna VISAR...
Looking to build a two way radio system.
You will have to have a vehiclular repeater that is in another band than the mobile so if your portable hand held radios are on UHF then I would advise a VHF high band repeater set up.
It will have to be a cross band setup meaning it will recieve UHF and transmit on VHF and also the opposite direction.
It will have to be programmed with CTCSS or PL of some kind to avoid interference and don't forget it will need to be FCC licensed for those frequencies if it is in the Business band.
Some mobile radios can be wired up through a mini controller and run that way if it is compatible.
Apr 28, 2009 | Motorola For SP50 7.5v 1500mAh NiCd...
HT 1000, MT1000, Radius P110 Tx problems
Sorry about taking so long to respond. These radios have worked properly in the past. They have increasingly become worse to the point they will not Tx. I have tried to com-cate with a good radio but unsucc. I'm thinking the Tx freq has been altered? Can one freq (Tx) be altered and not the other (Rx) or will both become altered?
Oct 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
V-800 trouble
when i turn on my radio it keeps beeping repeatly nothing else happens
Jul 29, 2007 | Vertex iTECH iQfive iQplus Yeasu--VX800...
Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free Usb Prog Cable Software Cd Free Logo
99 people viewed this question
Top Dual Radio Communications Experts
BJ Russell
Steve
Are you a Dual Radio Communication Expert? Answer questions, earn points and help others
