Tronic z24230 - Computers & Internet
Noisy Singer Touch Tronic 2010 sewing machine
the noise could be from the needle /hook timing, or bobbin carrier
take it to a service center for a service and to find out the worn/ loose parts
Dec 21, 2015 | Singer Sewing Machines
Singer touch tronic 2010 only sews in reverse
Here is a link to the owner's manual.
http://www.manualslib.com/manual/154331/Singer-Touch-Tronic-2010.html
Was this running ok, the poof?
There might be a reverse option on one of the selections switches.
If it has sat for a while, it might need servicing; gummed up inside.
Feb 05, 2015 | Singer Sewing Machines
How long does it take a tronic 150w power inverter to be fully charged.and how long does it last after being disconnected from charging?
This device is meant to convert DC power from a car battery and similar devices into AC mains power suitable for running small appliances. It is not intended to be an energy storage device. Once plugged in, it does take a few seconds to reach peak output and will remain active a few seconds after input power is removed. This is due to the slow collapse of the magnetic field generated by the internal transformer that feeds the AC output. You'll notice this same effect in your laptop charger if it is equipped with an LED indicator light letting you know it is energized.
May 08, 2014 | Power Tronic Computers & Internet
I have 54 series AG-TRONIC generator, about 25 yrs old used less than 100 hours. There is no output voltage, so I flashed the field with 120volts -should have been 12 volts DC. This did not solve the...
i have a older ag tronic generator the 5hp. briggs motor need rings i can,t seperate the generator from the moter to install new rings any help would be helpful lonniebeers@yahoo.com
Sep 27, 2010 | Electrical Supplies
I need a wiring diagram and or a color code chart for the wires and plugs coming out of a "Power Tronic" switching power supply model SK-4145DE. 145 watt power supply. Thanks for your help.
Many power supplies have a chart on the side of the case.
Here are the wire colors for an ATX type supply:
RED +5, YELLOW +12, White -5, Blue -12, ORANGE +3.3,
PURPLE +5VSB, GREEN Power On, BLACK -Gnd (common).
Feb 14, 2010 | Power Tronic PowerTronic 145W Switching...
TRYING TO FIND A CODE FOR MY CUTIS MATHIS TRONICS T.V. ON MY ONE
here are the codes.
Curtis Mathes 0047, 0054, 0154, 0451, 0093,
0060, 0702, 0030, 0145, 0166,
1147, 1347
You can also get the setup info here
http://www.solidsignal.com/manuals/URC-3021%20Remote.pdf
Dec 16, 2008 | One For All URC-3021 Remote Control
Key tronic wireless mouse quit working
Sounds simply broken to me. Time for a new mouse.
May 23, 2008 | Key Tronic UNPLUGGED PS2SB01...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
