Question about Microwave Ovens
Whirlpool microwave g2 - Panel lights but no text visible
How do I fix the panel or what part do I need to have the menus and clock become visible?
  • Microwave Ovens Master
  • 2,113 Answers
It is a logic problem or at least electrolytic capacitors that dim the display too far. The display could be repaired if it isn't a ic (logic) problem if it is then you need the whole display replaced
Posted on Nov 30, 2013
SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Posted on Sep 24, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: keypad on microwave wont work
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: micriowave key panel
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off. You have to make sure all the old adhesive is off.
Then peel the backing paper from the new keypad and carefully press the new keypad in place. You need to be precise - you cannot apply it, peel it off, then reapply it.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Feb 03, 2008
SOURCE: Control panel on a whirlpool microwave
SOME ELECTRONIC CONTROLS HAVE A LOCKOUT FEATURE THAT IS ENGAGED AND DISENGEGED BY HOLDING A CERTAIN BUTTON FOR 5 SECONDS. LOOK FOR A LOCK PAD AND HOLD IT FOR 5 SECONDS TILL IT BEEPS.
IF NOT AVAILABLE, THE TOUCH PAD MAY BE UNPLUGGED FROM THE MAIN P.C. BOARD OR MAY BE DEFECTIVE.
ALSO, TRY UNPLUGGING THE MICROWAVE FOR 5 MINUTES
TO RESET THE MICROCOMPUTER, THEN PLUG IT BACK IN AND SEE IF IT WORKS.
AN ELECTRICAL OUTLET NOT WIRED WITH PROPER POLARITY OR NOT GROUNDED CAN AFFECT ELECTRONIC APPLIANCES ALSO.
Posted on Mar 28, 2008
How to set the clock on this ,Opel whirlpool microwave
Usually one presses the control panel Off/Reset button, presses the clock button, enters the time (eg. 710 for 7:10) and presses the clock button again.
Jun 13, 2015 | Whirlpool Microwave Ovens
Lights on but keypad not working
The lights in the oven are seperate from the one in the control panel/clock. IF the control panel and clock dont work then it is not something that is easy to fix. Could be the fuse of the controller board.
Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool microwave
    • 1 Press the "Clock Set/Start" or "Clock" button on the control panel.
    • 2 Enter the time of day using the number pad, or use the "+" and "-" buttons to scroll to the correct time.
    • 3 Press the "Clock Set/Start" or "Clock" button once again to save the time.
Apr 11, 2012 | Microwave Ovens
G2 touch screen doesn't work any longer
You must remove the vinyl cover from the control panel and wipe down the face underneath it with denatured alcohol. It's pretty tricky depending on your mechanical caliber.
Then clean the inner side of the vinyl cover the same way. Caution don't soak the power unit just dampen a cloth, this goes for the cover also!
Aug 13, 2009 | Microwave Ovens
Was heating up food and all of a sudden nothing works on the microwave, nothing, clock, light, buttons, nothing..
sounds like your circuit breaker kicked or your fuse blew. go to your electrical panel and see.
Apr 21, 2009 | Whirlpool MH7140XF Microwave Oven
Have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feb 28, 2009 | Whirlpool MH3185XP Microwave Oven
Whirlpool microwave g2- touch screen. The touch screen does not work properly. If you touch a command a differnt command/menu comes up. Some menus are inaccessable.
We repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 10, 2008 | Microwave Ovens
GE profile microwave
Most likely problem is your Smart card has fried.Its located on the removable panel that your display is attached to.If you remove the screws that open this Clock Panel (un plugged from power first) the display panel will swing down and you will see the circuit board I mention (Smart card/control board ).Look for a visible burn on this board.If you see one ,replace the board. Please Rate This !
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
Apr 30, 2008 | Whirlpool GH7145XF Microwave Oven
Whirlpool RMC275PD microwave won't start
I would first suggest unplugging the oven for a few minutes to give it a reset. On Whirlpool brand microwaves, you will hear a series of beeps when you hit START if one of the following is true: - the control panel is not programmed correctly - the door is not shut - there is a problem with the door latch system - there is a problem with the control panel If you do not have your owner's manual, you can download it here: http://www.whirlpool.com/custserv/literature_search_results.jsp?searchTerm=RMC275PD#literror It doesn't sound like the control panel is locked. When the control panel lock is activated, you will see "Loc" and a lock symbol in the display and only the clock, timer, and oven light will operate. If that does not solve the problem, then you have oneof the other problems as listed above. If you need further help, please reply / add a comment here.
Nov 18, 2006 | Whirlpool RMC275PD Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
