Question about Kitchen Appliances - Others
Cannon electric blanket tc1480 manual
Turn off auto off feature
ON MY JASON ELECTRIC BLANKET I HAVE FLASHING P WHAT DOES THAT INDICATE CAN I RESET OR DOES IT INDICATE THE BLANKE IS DAMAGED IN SOME WAY AND I SHOULD NO USE
That means the unit is not plugged in from the control to the blanket. If you have it connected, then the element in the blanket or one of the thermal safety features is open.
Apr 25, 2018 | Home
How do I turn off the auto timer on my cannon Chichester.
This is a Cannon Cooker not a Canon Camera You're in the digital camera section Anyway try here
http://www.manualslib.com/manual/24256/Cannon-Chichester-10420g.html
Aug 30, 2015 | Cannon Cameras
Can electrical cord for electrical blankets go between mattress and box spring
Wires should be on the floor. Do not put them where you may lay on them and or cause friction on them (even if it's just rolling over during the night).
Sep 19, 2014 | Sunbeam Twin Electric Auto Heated Blanket-...
Sunbeam electric blanket repair waynesboro ms
wash the blanket then throw it in the bin
water and electrical components do not mix
electrical blankets are just a resistor element in ceramic covering and if you put that in a washing machine that is the end of the insulation
Mar 18, 2017 | Sunbeam California King Arlington Heated...
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
Apr 07, 2013 | Biddeford Blankets Heated Mattress Pad...
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Kitchen Appliances - Others Logo
48 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
