Question about TEKK Fitness Two Treadmill
Treadmill slows down and stops
I have a nordic track treadmills 2000. When one starts it, It runs, slow downs and stops. This happens without any load on it. Any suggestions?
  • Anonymous Mar 26, 2014
    I was running and slowing in down and it just stopped. I have unplugged it and restarted but the belt won't turn at all. Help?
    Sergeant:
  • 175 Answers
Hi..probably the reason to this problem may be due to
worn belt and deck or a belt that needs lube.
check it out..
thank u..
kindly rate my response..
Posted on May 09, 2009
STARTS AND THEN ITS STOPS??
If the timer is set it will always stop at EXACTLY the same time.
If the motor is overheating, it will usually slow down before it stops; and the time will be a little different each time.
Congratulations, I only know one other person who has worn out a nodic track.
Feb 03, 2015 | Nordic Track Nordictrack C2200 Treadmill...
Nordic track 1000 works only on speeds 1 and 7
adjust the speed sensor, see the diagram attached. clean it and test it for open or faulty. Tight the connector very well.RUN the software calibration for easy diagnose, and fix it. God bless you3_22_2013_4_23_05_pm.gif3_22_2013_4_23_19_pm.gif
Mar 22, 2013 | Nordic Track NordicTrack Treadmill, A2550
My Nordic Track C2200 Treadmill will stop in mid run. The timing when it happens is random. I can pull the safety tab out and put it back in and run for a bit till it stops again. Any suggestions on...
It it completely shuts down ( console shuts down then restarts) it may be a static electricity problem. Check your outlet to be sure it is grounded. Check the plug . The ground pin may have been removed.
Jan 02, 2011 | Nordic Track Exercise & Fitness
My treadmill is telling me the wrong amount of calories burned and the wrong speed at which I am traveling. For example, I hit the button that says 6 mph, but the treadmill says I am running at 9.7 mph....
I had the same problem with my Nordic Track. I had somehow changed the display to metric readings.
Solution: Hold the stop button down while inserting the key, push the speed up or down button to change it back to english, remove key and you are good to go. Re insert the key and it should work fine. Hope this helps.
Nov 27, 2010 | Nordic Track Nordictrack Adventurer...
Nordic Track C2000 starts and then stops.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 21, 2010 | Exercise & Fitness
I have a NordicTrack EXP 1000 X. Just bought it froma guy on craigslist, and it was working fine at his house. Messed with the belt tensioner bolts a bit when I brought it home, and now when I walk/run on...
It sounds like the belt is bogging down, this condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
The only certain way to test for a worn walking belt is to take a DC amp draw . Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test.
The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
May 23, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
May 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
Incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Oct 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Treadmill goes normal speed until I get on it and then it slows down
When was the last time you placed the correct lubrication between the walk belt and the walk board. This is a very common issue. Make sure you DO NOT use anything from an aerosol can. The acetone will cause the belt to get dry, hard and crack.
Good luck.
Jun 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
My treadmill will go normal speed set at until you start walking on it and then it slow way down. Why would it do that?
Try looking for a problem in the power.if that doesnt work,send it to a technician or if you had a warranty on it even better.
Jun 15, 2009 | Nordic Track NordicTrack Treadmill, A2550
TEKK Fitness  Two Treadmill Logo
921 people viewed this question
Top TEKK Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a TEKK Exercise and Fitnes Expert? Answer questions, earn points and help others
