Problem with washing machine
Inglis superb 2 speed/4cycles model # UO-54001 drains when on rinse and sometimes counter does not work and just keeps on filling up water at the same time draining the water.
  • 1 more comment
  • Jesa
    Jesa Dec 06, 2013
    if i am using it the first time it runs properly. but when i used it for my next batch of laundry the problem kicks in.
  • Elmer Lynn
    Elmer Lynn Dec 06, 2013
    how old is this washer and did u put the n line at the top behind washer if hose is instaled to low the water will keep running out and it will keep adding water
  • Jesa
    Jesa Dec 18, 2013
    I really don't have an idea. it is a second hand product. does not come with a user guide or an installation guide. so i really don't know if we installed it right/properly. sometimes the counter does not work too. if you can help me that would be great. thank you
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
The lid has a double switch
Posted on Nov 29, 2013
  • Jesa
    Jesa Dec 04, 2013
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Hi, our washing machine starts to pump out water and then stops. The counter still keeps going but without the machine actually doing anything. The water doesnt drain out sometimes and the no drain light...
Possible failure of the main program controller unit as it fails to contact at times and resets .
Since you mentioned that it is erratic the program is not executed to contact to the job of the cycle and so the drain pump/valve is stopped mid way.
Mar 25, 2011 | Washing Machines
Manual for Inglis Superb 2 washer
Since no model was given I cannot provide you with a manual. Click HERE you may find the manual you are looking for.
Mike
Dec 20, 2010 | Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Selection dial has come loose.
Found I could unthread the knob (counterclockwise), then removed the selection plate, and its adapter. Noticed that it was originally welded to the plate, via 3 palstic studs. I was able to determine that the two plates would ONLY align in one postion, and then was able to ReGlue them together, courtesy of No More Nails. All is well in Washerville again.
May 16, 2009 | Whirlpool Inglis IP4400 Washer
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Inglis Superb 2 washer,
Inglis cloths washer Model L038001 will not drain or agitate
Jun 25, 2008 | Washing Machines
Kenmore Super Capacity stuck on rinse
Krom, sounds like the machine is syphoning. Check the drain hose and make sure there is a air gap and that it is not too far down the standpipe or drain. To test it hold the drain hose right at the drain top and see if the problem stops...Catriver...post back.
Jan 18, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
