Question about Refrigerators
Engel fridge not cooling
Green light on no compressor starting changed batterie
    Champion:
    Habit-Forming:
  • 275 Answers
Check the little compressor is getting power.
Posted on Nov 29, 2013
5 Suggested Answers
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Westinghouse RP423 Freestyle fridge cooling failure
I am going to assume you are in the UK. the voltage is higher than most household refrigerators here in the USA. Disconnect power to refrigerator and check continuity on two of the three terminals of the compressor at a time until you measure the resistance in the windings all the way around. The terminals should be marked R, S and C. (Run, Start and Common) you should get a reading with your multimeter all the way around. When you have done this and have the readings I want you to touch one end of your multimeter to the metal pipes or any clean metal outside the compressor and the other to one of the three terminals one at a time like you tested before. With your multimeter set up the same, see if you get a reading from metal housing to the three pins, or terminals c, r and s. You should get no reading. If you do, the compressor is a burn out and on the first test if you don't get a reading on the two at a time test between two post that is considered to be open or broken windings. The compressor does have an internal overload that may be open also. But if cool at time of test, and it shows up the compressor in bad. Let me know what you find...Thanks, Sea Breeze
Posted on Apr 24, 2009
  • 4793 Answers
SOURCE: engel 43 qt fridge freezer stopped cooling.
have you checked the compressorpump is getting warm(a sure sign its working.sometimes a little tap works)
Posted on Feb 11, 2010
heatman101
  • 43501 Answers
SOURCE: Loud click,compressor starts, immediately stops.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
Fisher and paykel xrss 267BB fidge freezer
The system is either blocked or you have a gas leak but i would expect it is blocked and the only way to find out is to get a refrigeration engineer to check it for you, but explain the problem to him first and make sure he can help before you spend money.
Jul 19, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
How long can you expect a fridge to last these days??
Hi Joanne
Wow, Is that an open question.....
How long is a piece of string...
I get what you mean though...
Only your Engel Service Dept knows for sure.
They see the returns.
Does it have a compressor or is it based on Heating Elements like an RV Fridge.
If you can hear the compressor running inside, you will know. Compressors don't like being tipped on their side.
I have 1 fridge & 1 Freezer in the back storage room that have been running for thirty years. But I don't think they make em like that any more.
Look after it. Keep the vents clear & hope for the best.
Cheers
May 20, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Long running periods with Engel B 12v fridge
the owners manual will tell you but yes most do
Apr 11, 2010 | Engel Freezer MT 27F-U1
Engel 43 qt fridge freezer stopped cooling. the compressor comes on, the fan is blowing but not cooling
Feb 11, 2010 | Engel 43 Qt.Portable Freezer.
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge freezer not working
Thermostat can easily be determined, it has knob or a display for digital control. If it is a knob try to set it to high cool but if wont work.Try to unplug the unit and pull out the thermostat set it to high cool and check if there is a resistance on its terminals. Or check for open overload compressor Or may be the winding of compressor is open.
Dec 23, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
