Question about Edge Products 2004 GMC YUKON XL 1500 85250 Evolution CTS Gas Programme
2004 gmc yukon what causes speedometer to work sometimes?
    Problem Solver:
  • 5 Answers
It is most likely the stepper motors for the gauges. I had all of mine replaced by a company in Louisville for around $125. Mine was more the tach and oil press.
Posted on Dec 08, 2013
My speedometer jumps around
This is a common issue with the 03-06 Yukon gauges and is caused by failing gauge motors. It can be repaired though, check this page for details - Yukon speedometer problem there's also a DIY guide there if you like to work on your vehicles yourself.
-DrSpeedo
Oct 31, 2010 | 2003 GMC Yukon Denali
My gas gauge & speedometer gave out on my 2004 gmc yukonis there any recall on this type of situation?
Yes there is a recall for erratic gauge readings. They will supply new instrument cluster and labor to install it at no charge to you. Tell the service writer that your gauges only work sometimes and they'll help you out. worked for me!!!
May 20, 2010 | 2004 GMC Yukon
Replace spedometer cable 2003 gmc yukon xl
There is no speedometer cable on the 2003 Yukon, if there is no transmission issues like shifting problem. Your instrument cluster has gone bad, to pinpoint. Your stepper motor to your speedometer gauge has failed and needs to be replaced. You can do a search on Ebay for the stepper motor for around $10.00 which is better then the $400.00 cost of another instrument cluster.
There was a TSB on the replacement of the instrument cluster for your Yukon free of charge. The only cost to you is the labor charge unless your willing to do the job your self. Just go to the Gm Dealer and give them this TSB Number: # 07187C: Special Coverage Adjustment - Instrument Panel Cluster Gauge Needle Function - (Mar 20, 2009)
Subject:
07187C -- SPECIAL COVERAGE ADJUSTMENT - INSTRUMENT PANEL CLUSTER GAUGE NEEDLE FUNCTION
Models:
2003-2004 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT
2005 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT (U.S. ONLY)
2003-2004 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE
2005 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE (U.S.ONLY)
2003-2004 GMC SIERRA, YUKON, YUKON XL
2005 GMC SIERRA, YUKON, YUKON XL (U.S. ONLY)
Some customers of all 2003-2004 model year and certain U.S. 2005 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles have reported that one or more of the instrument panel (IP) cluster gauges stick, flutter, or become inoperative. This may cause inaccurate readings, including the speedometer and fuel gauge. Special Coverage Adjustment This special coverage covers the condition described above for a period of 7 years or 70,000 miles (110,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
Dealers are to replace the instrument panel cluster after the condition has been verified. The repairs will be made at no charge to the customer.
For verified failures between 70,001 miles (110,001 km) and 80,000 miles (130,000 km) on U.S. vehicles, dealers are to provide the customer with an instrument panel cluster (IPC) only. Any additional costs, including labor to replace the instrument panel cluster, will be the responsibility of the customer. Dealers are responsible for the return of the customer's IPC back to the Electronic Service Center
Thank you for using fixya and good luck.
Apr 28, 2010 | 2003 GMC Yukon XL
2004 GMC Yukon. Speedometer is reading much faster than my actual speed. Then sticks sometimes. Checked with GM dealer here and they said that if my vehicle had less than 70K they would check the speed...
If you have cruise control in the vehicle you can test to see if it's the speed sensor or the cluster. If cruise control works, the problem is in the cluster not with the sensor. And it's most likely the stepper motor issue.
There was not a recall, but there was a class action settlement where GM agreed to extend the warranty on certain vehicles for this problem. Check www.gmspeedometerrecall.com to see if you qualify.
Feb 19, 2010 | 2004 GMC Yukon
I have a 2005 GMC yukon and the speedometer is way off. If I'm going around 65mph the speedometer shows I'm going 100mph. and when I stop or turn off the truck the speedometer stays at 40mph.Is there a...
This is really common on the 03-06 Yukon instrument clusters. It's caused by failing stepper motors on the circuit board and can be repaired. Check out this page for more about it and how to get it fixed - Yukon instrument cluster repair
Dec 28, 2009 | 2005 GMC Yukon
Speedometer works sometimes on 2004 yukon denali just replaced speed sensor
you need to tighten the cable that comes from the odometer to the drivetrain ... they sometimes become loose from vibration... this should fix it...
good luck
Dec 23, 2009 | 2005 GMC Yukon Denali
My instrument cluster not working on 04 gmc yukon i checked fuses and harness for cuts or frays
disconnect ur positive battery cable. make sure not to set alarm with remote. let set for about 5 minutes, this happened to my 2003 gmc yukon xl and it actually worked
Mar 15, 2009 | 2004 GMC Yukon
Speedometer
your speedo cluster is bad. I replaced mine and then a recall came out last year(?). GMC reimbursed me for unit installed at the GMC dealership. Just need a copy of your invoice or ask your GMC dealer to complete work if recall is still in place.
Jan 17, 2009 | 2004 GMC Yukon
My speedometer is stuck
Typically on a Yukon instrument cluster this is caused by failing stepper motors on the cluster's circuit board, it can be fixed though. Check out this page for more about Yukon speedometer problems and how to get it fixed - Yukon speedometer fix
Dec 18, 2008 | 2005 GMC Yukon
Edge Products 2004 GMC YUKON XL 1500 85250 Evolution CTS Gas Programme Logo
91 people viewed this question
Top Edge Products Optics Experts
Michael Sullivan
Michael Sullivan
Level 1 Expert
Lawrence Oravetz
richie46
Are you an Edge Products Optic Expert? Answer questions, earn points and help others
