Question about Maytag Dryers
Maytag model sdg2606aww
Flame goes all over rather than straight out on gas dryer
    Genius:
  • 1,198 Answers
Usually the fan draws the flame down the tube. Make sure the fan and all the ducting is clear, including the lint filter.
Posted on Nov 29, 2013
docjohn174
  • 943 Answers
SOURCE: Gas Dryer
HI thanks for your question. the problem is with the coils on the gas valve. one has failed. they come in a pack of 2 replace the coils. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 14, 2008
SOURCE: maytag dryer not heating
Many gas appliances have safety devices that all need to be functional or you will not be sucessfull in passing fuel to the burner assembly.
There are 2 or 3 electrically controled coils on the gas valve (electromagnetic), these lift a pin in the control and gas flows as requested, these can fail and are realatively inexpensive and easy to replace, $4-25 depending on how many and where purchased.
Other sensors are 2-limit thermostats, radiant sensor, heat sensors, motor temp sensor, humidity sensor, switches (door etc.) all must function in the system to allow correct performance, lastly control panel, also most problems involve cleanlyness of the entire system and all associted exhaust piping.
There are no appliances that are free from maintanance so all require inspections and regular cleanings.
Posted on Jan 10, 2009
protek480
  • 1714 Answers
SOURCE: Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Posted on Oct 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Dryer makes a loud squealing when first started
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 05, 2009
Testimonial: "Removed the drum and oiled the various rollers Quieted the noise. Sounds like a new one again. Thanks "
  • 221 Answers
SOURCE: Maytag Gas Dryer (LDG4910AAW): Flame will not stay
Hi, sounds like a blocked vent hose, try disconnecting it and see if the flame stays on.
Posted on Jan 17, 2010
Igniter comes on will not let the gas in. The gas burner does not come on Maytag model dg882s
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
FLAME SENSOR
Sep 14, 2011 | Maytag Dryers
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I replaced the idler pulley and pulley arm on my Maytag Dryer model#SDG2606AWW, and now I don't have enough tension for the drum to turn.
http://www.pcappliancerepair.com/model-display.php This site shows your belt going around the motor a half turn, grooves to the pulley. Then you have to wind up the spring-pulley and put the belt over the roller a half turn. That should take up the slack. The packaging of a new belt should show how it goes.
May 12, 2009 | Maytag Dryers
Drum belt tension
I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
Problem solved.
May 11, 2009 | Maytag Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
