Question about IBM IntelliStation M Pro 6849 PC Desktop
IBM intellistation 6849 will not turn on subsequent to cleaning.
Cleaned internally (air sprayed) above referenced system. However, system will no longer turn on. System board appears to receiving power as indicated by green light on system board. Checked all connections, nothing appears out of the normal. Any sugestions?
  • Chris Hingee
    Chris Hingee May 11, 2010
    Try reseating the RAM modules. If that doesn't work take it to your friendly computer shop to test them or install them in another computer.
  • 70 Answers
As you have opened the cabinet and cleaned, the ram might be loosened i suggest remove the ram blow out the dust in the ram slot and fix the ram properly in the ram slot and then to if the system doesnot power on check the front panel connections whether you have connected properly.
Posted on May 30, 2009
  • Samuel Jayakumar May 30, 2009
IBM INTELLISTATION M PRO does not power up
Have you tried any troubleshooting? It is most likely the System board or power supply. You could take a known good power supply and swap it out to see if it will turn on, if not it's the system board.
Jan 02, 2014 | IBM IntelliStation M Pro 6218 PC Desktop
I am not geting suitable driver for IBM IntelliStation E pro 6226 model
try download driver here:
http://www-947.ibm.com/systems/support/pc/
Mar 27, 2011 | IBM IntelliStation E Pro 6226 PC Desktop
IBM IntelliStation M Pro 6219-10u How to update the bios with a USB pen drive as my floppy drive is not working.
As it is obvious you do not have the necessary skills or knowledge I would advise you against any attempt to do this.
The ONLY reason to perform a BIOS update is if there is a significant change in the BIOS firmware which will solve a problem you may be having.
If you have no problem-Don't try to fix it!
BIOS updates should only be carried out by people with a working knowledge of systems. If done incorrectly you can render your system inoperable.
I do not advise this to demean you in any way, just to help you.
Dec 25, 2010 | IBM IntelliStation M Pro 6849 PC Desktop
What are the compatible BIOS for intellistation Z PRO 6223 work station
Here is the link to your system BIOS tools and updates:
http://www-947.ibm.com/systems/support/supportsite.wss/supportresources?categoryind=5050379&selectedButton.x=12&selectedButton.y=13&selectedButton=category&familyind=5050008&brandind=5000004&osind=5053379&typeind=5178890&modelind=0&matrix=Y&taskind=2
Dec 17, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Air is coming out but no primer
  1. primer viscosity to thick
  2. internal filter clogged
  3. internal passage clogged
  4. gun not adjusted properly
  5. high build primer uses more air pressure
  6. wrong needle and fluid nozzle
  7. gun needs cleaned
Aug 07, 2009 | Vaper 4 Piece Set 3 Gravity Spray Gun +...
No audio output with winxp sp2
download the rihgt drivers for your motherboard.
try this one:
http://www.drivershq.com/Drivers/Devices/IBM-IntelliStation-M-Pro-SoundMAX-with-audio-Drive/1916/19/Drivers.aspx
Aug 06, 2009 | IBM IntelliStation M Pro 6849 PC Desktop
IBM Blue Screen
I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
System:
IBM 6868 52A M-Pro Intellistation
2 x Intel P3 866 CPU's 256 mb cache
2 GB ECC RD Ram
2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
ATI 9520 AGP 128mb Graphics
Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
Dual Boots with Xandros Linux Desktop Destop 3.01C
Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
IBM IntelliStation M Pro 6849 PC Desktop Logo
103 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
