Question about Panasonic Palmcorder PV-DV53 Mini DV Digital Camcorder
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
Lightly-used Panasonic camcorder shows black and white horizontal line image on LCD screen.  This occurs when the screen is flipped out at 90 degrees to the camera body (the regular "out" position used for filming).  When the LCD screen is rotated upside-down (twisted on the pivoting joint) and then hinged back toward the camera body, the horizontal line image changes somewhat - different horizontal line patterns appear.  Then at about 30 degrees from camera body, the true image to be captured suddenly appears.  Even when screen is pushed further and snapped back into camera body, with the LCD facing outward, the real image continues to come through just fine.  It looks like some connection in the swivel/hinge joint might be off. I'm wondering if anyone's had this trouble, if they've been able to fix it, any ideas on how to determine what's going on, etc.  Wondering if maybe there's just some debris caught in the joint, or...?  Thank you!
  • 95 Answers
The hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Posted on Jun 13, 2008
SOURCE:
The lcd screen has stoped working om my panasonic pv-gs35. the veiw finder still works. is there a mode i changed or any idea whats wrong...thanks, kyle
HELLO! IF YOU MOVE THE LCD SCREEN BACK AND FORTH AND YOU SEE PICTURE FOR A SECOND THEN LCD HINGE MUST BE REPLACED,IF NO PICTURE AT ALL MAYBE PROBLEM ON LCD BOARD.
Dec 25, 2009 | Panasonic PV-GS35 Mini DV Digital...
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
Describe your Panasonic PV-GS35 Mini DV Digital Camcorder Problem: When I turn the camcorder on in the video camera mode the lcd panel and th evf show black, it does not show current picture to record. All...
There was an earlier post that explained the black ribbon between the LCD viewfinder and the body of the camera is split. You would have to buy a new LCD viewfinder for about $90 or send it back to them to fix for around $250. The same thing happened to my camera and I can actually is the split. If you close it down more than half way the picture shows up. I called Panasonic and they said you have to buy the whole LCD, that you can't just buy the ribbon. They don't even have a part number for just the ribbon. Good luck.
Oct 18, 2009 | Panasonic PV-GS35 Mini DV Digital...
I have a Panasonic pv-gs35 Camcorder when I open the lcd monitor the screen turns all white. The viewfinder works ok. Should I have to replace The lcd monitor?
first check the LCD connection, try to reconnect the flexible cables on the LCD board,
second, replace the flexible cable goes throungh hinge.
if those won't work, you may need to replace the LCD or main board.
May 17, 2009 | Video Cameras
Panasonic GS35
i suggest you insert a head cleaning casette to see if this removes the lines.the lines occur when one of the heads is dirty or not operating. if this does not solve the fault then the head might need changing.
Jun 16, 2008 | Panasonic PV-GS35 Mini DV Digital...
Thick lines on screen
May 27, 2008 | Panasonic PV-GS35 Mini DV Digital...
No image in viewfinder
CCD sensor faulty and has to be replaced ( you can playback fine but no image in capture mode ). Manufacturer's agent should repair this fault free of charge as you clerly bought a faulty product.
Aug 28, 2007 | Panasonic PV-GS35 Mini DV Digital...
Panasonic Palmcorder PV-DV53 Mini DV Digital Camcorder Logo
312 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
