Question about Reddy Heater-30-55,000 BTU Variable
Stopped lighting makes a noise, but wont ignite
  • 2,113 Answers
Replace the regulator
Posted on Nov 29, 2013
Oldsmobile alero 2001 making clicking noise wont stop
There can be a LOT of reasons for this. I assume you've been all through the car and found no loose objects, so the next best suspects are loose mechanical or electrical connections. If the noise is deep inside the dashboard, or under the car, you can TRY to locate and fix it, but should probably go to the dealer. If the noise is from the engine area, maybe it's an ignition wire arc-ing out (does the motor idle any rougher than it used to?). You can check by pulling into a garage or other dark place, opening the hood, and looking for a spark-light that makes the click. A handy person can fix this by installing a new wire set, maybe $50 or less. As long as THAT's happening, you might as well change the plugs, distributor, rotor and any other ignition bits requiring regular maintenance.
Apr 21, 2014 | 2001 Oldsmobile Alero
Not starting make clicking noise
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 08, 2013 | Harley Davidson FLHRCI Road King Classic...
Car won't start and makes a ticking noise
CHECK IF TURN SIGNALS WORK, USUALLY ON GM CARS IF A BULB IS BURNED IT WILL TICK FASTER, IT IS AN INDUCATION OF BURNT BULB - COULD BE FRONT OR REAR
May 19, 2010 | 1999 Chevrolet Cavalier
Hi, our 2003 focus wont start. The engine light, the ignition light and the oil light are all on. We have checked the battery and all the fuses but nothing there seems wrong. We've only had this car for...
could be the belt tensioner is bad. That will loosen the belt so the car battery goes weak and will make a bad noise. Could have gotten a defective alternator.
Mar 07, 2010 | 2006 Ford Focus
Car wont start. has power, lights , alarm works.
take your starter off and get it tested sounds like your problem
Jan 15, 2010 | 1997 Saturn SL
1997 Mazda Protege LX 1.5
replace the fuses and check all the wire connections unter the dash by the pedals and under the hood if that doesnt work get your computer checked
Apr 02, 2009 | 1997 Mazda Protege
Ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
Feb 11, 2009 | DCS Large Appliances Built-In Ovens...
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
Reddy Heater-30-55,000 BTU Variable Logo
29 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
