Question about Ovens
Replace oven thermostat
My ove gets extreamly hot
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Yup...remove and replace
Posted on Dec 02, 2013
My Baumatic BS65MS oven is cooking too hot, it burns everything. I have turned down the temperature, this doesn't help. What would be the problem?
You may have a stuck thermostat and that should be replaced because he's probably telling the other keep eating even though the temperature the temperature would be correct
think your new oven is too hot or too hot or too cold, you can adjust the temperature yourself to meet your specific cooking preference. You can also adjust your thermostat if your oven is not new, since thermostats may "drift" from the factory setting over time. See the "Adjust the Oven Thermostat"
Mar 18, 2018 | Baumatic Ovens
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
I am trying to unlock my oven
Often you lock the ove to clean it and it gets so hot inside that it will not unlock til it cools. give it some time. good luck!
Aug 31, 2010 | Ovens
My oven wont get to temperature why?
If oven is getting hot , but not hot enough, then the thermostat is probably faulty.if no heat at all, then you need to replace the oven element.
Please rate my solution.
Thanks.
Sep 09, 2009 | Zanussi Ovens
The baking element went out on our range. We
give me your model number and i'll tell you where its is  usually if its a built in ove its in the bac k so you got to pull it out a little lean it on something or one person hold it up and you take off the sheet metal cover and you'll see a thermostat back there
some thermostats have a reset button but if yo give me the model number i'll help you out also make sure you have 110 volts on each leg of the wall outlet where the oven is plugged in
Jun 07, 2009 | Ovens
Frigidaire oven is too hot by 50 deg.
Yes, I would say that the main oven thermostat is faulty and in need of replacing.
If you are in u/k then try the followinw.
www.espares.co.uk.
Hope this helps.
Plz leave feedback.
Thanks.
Dec 10, 2008 | Ovens
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Ovens Logo
32 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
