Question about Car Audio & Video
I need the wiring color coding of jvc kd-r526
    Problem Solver:
  • 4 Answers
All branded car stereo system color cods are same. FR-speaker:brown,brown with black. FL-speaker:white,white with black. RR-speaker:violet,violet with black. RL-speaker:green, green with black. Yellow:battery. Red:key main ( acc). Black:ground. Blue and blue with white: amp remote or power antenna. Thanks.
Posted on Nov 29, 2013
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
etirbynnor
  • 655 Answers
SOURCE: I NEED A WIRING GIAGRAM BECAUSE THEIRE IS NO COLOR
Hello nls124,
You can download a copy of the manual here at Crutchfield. The wiring color code is on page 31.
Vehicle wiring harnesses and color codes change frequently, but most likely you can get an aftermarket harness by Metra or Scosche that will fit your vehicle. That way, you can make the splices to the harnesses and avoid cutting or tapping into the vehicle wiring. Both www.crutchfield.com and www.sonicelectronix.com have harnesses for most makes and models.
Hope this helps.
Posted on Jun 11, 2009
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
  • 26 Answers
SOURCE: need info on wire color coding
Try going to the crutchfield website and look for help installing stereo. they can get you vehicle specific wiring codes for free. Also, almost everey stereo has common color codes for wiring. red- switched batt. +, yellow-constant batt. +, black= ground, blue- power anrenna, etc.
Posted on Apr 12, 2010
kenw392
  • 2226 Answers
SOURCE: why does my jvc kd-r526
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Posted on Jun 02, 2011
My receiver is JVC model no KD-R526.its saying check wiring on screen
This means the amp is sensing a short, if you can it would be easiest to unhook the speakers one at time to see if it goes away.
May 20, 2016 | JVC Car Audio & Video
My JVC model KD-R526 is always showing unit warning check waring then reset how to fix this
If the reset doesn't clear it, then it needs to be sent to service. If you are a tech, then write back with details.
Feb 26, 2015 | JVC Car Audio & Video
Hi,Excuseme.I have 16 pin connecter of the JVC KD-S575. But,color of the wires does not match the position of the pin.I want to know the position of the 16 pin connecter of the JVC KD-S575 It has 2...
Car manufacturers donot keep color code. Your best bet is to order a universal adapter. JVC color code can be found in the instruction book. I will attach a picture. upload is not working. email me to jpulickal@gmail.com
Oct 02, 2013 | JVC KD-S570 CD Player
Jvc Manuals
The wiring diagram is on the last page of the manual at http://www.jvc.co.nz/assets/pdf-manual/KD-R526.pdf
May 15, 2013 | Car Audio & Video
Jvc Instruction Manuals
The wiring diagram is on the final page of the manual at http://www.jvc.co.nz/assets/pdf-manual/KD-R526.pdf
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
Need info on wire color coding for jvc car cd player: JVC KD-G140
Apr 12, 2010 | JVC KD-G140 Car CD Player
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
