Question about RCA Televison & Video
Lxi turntable completely stopped rotating. when i gently jogged it, it turned but at a much higher speed than33 and a third. when i returned the toner arm, it would not start again. i jogged it a second time then had the speed issue. any help would be appreciated,DAVE
    Top Expert:
  • RCA Master
  • 12,223 Answers
Make this test see the photo attached. when you hit any key THE LED MUST BE ON, use the digital camer or cell camera. Otherwise open the r.control and clean the keypads from dirty, oxide, corrosion, and replace the old batteries by new ones. tight the springs batteries with plier and clean it with alcohol isopropyl 100%
God bless you
lxi turntable  completely stopped rotating. when i - 65cfeca0-172f-4b53-a559-3e3fab3d7093.jpg
Posted on Nov 29, 2013
Technics sl1210 mk2 motor speed error
pls use the search function, this is answered 50 times
Jan 08, 2014 | Technics SL-1210 Turntable
My Crosley Radio CR6007A-MA Recording Tech Turntable squeaks with each revolution is makes. I want to know how I could fix it.
I'm not familiar with this specific turntable but there are some general tests that you can try. As with any problem try to identify the source of the problem by working through an elimination process.
  1. Does the problem occur at all speeds or just one, which would indicate an issue with the belt drive system.
  2. Does it squeak continuously or only at certain points as the turntable rotates? Put a marker (a lump of blue-tac would work well) towards the edge of the turntable and note the point(s) where it squeaks.
  3. Rotate the turntable by hand with the power switched off, vary the speed you rotate it at. Can you feel the squeak as well as hear it?
  4. Is the turntable on a level surface and is the turntable itself level (parallel) with the base - if it is not this might suggest that one of the suspension mounts has failed. Peer under the edge of the turntable all round to make sure it is not rubbing against the frame / base.
  5. The turntable is driven by a belt system off a separate electric motor. Usually these motors are hung from the frame on a sort of elastic band arrangement. These bands become perished and can break or just stretch unevenly, which causes the motor to hang at a funny angle. Sometimes this can result in either the pulleys rubbing against the side of the frame (would normally be a fairly continuous squeak). At lower speed settings (e.g. 33 rpm) this may also cause the edge of the drive belt to rub against the bottom of the larger (45 rpm) pulley above it. If you can't find a supplier of the correct replacement motor suspension band you may be able to fix it with ordinary rubber bands but it may take a bit of fiddling to get the motor perfectly level at exactly the right height.
  6. With the motor running and the turntable rotating gently press on the rim of the turntable with your finger as a brake to slow the turntable down slightly. Does the squeak increase or decrease in volume or pitch? If it gets louder or higher pitched that probably means that the drive belt is slipping slightly (in which case some records may sound a bit slow when you play them). You can either replace the belt or purchase a can of 'belt dressing' spray (obtainable from most good tool shops) and apply a light coating to the inside surface of the drive belt - don't over do it. The best way to do this is by rotating the turntable by hand whilst gently squirting a little of the spray onto the belt close to the point where it goes on to the pulley on the turntable drive spindle. Take care not to get the spray on any other moving parts or the electrical components as it is sticky and hard to clean off. If this is the problem you may need to re-treat periodically.
  7. The motor and belt drive system may be accessible either by lifting off the turntable deck (platter) itself or by turning the whole thing upside down (make sure you secure the pick-up arm before you turn it over!) and unscrewing the bottom of the case. Some turntable platters have viewing holes in them which are revealed by lifting off the rubber mat.
  8. Gently slip the belt off the pulley wheels on the motor and on the bottom of the turntable spindle. Check the pulleys for any lumps of dirt or fluff that may be causing problems. Also check that the drive belt is clean with no lumps or flat shiny spots. If the belt is worn replace it.
  9. If appropriate turn the turntable up the right way again.
  10. Rotate the turntable by hand. If it still squeaks the problem is in the turntable bearing and may easily be solved with a bit of lubrication. Some manufacturers will supply a little tube of special grease. If you don't have this a bit of Vaseline /petroleum jelly will do quite nicely. Don't use a silicon based lubricant like WD40 as this will dry out again over time.
  11. Try rotating the motor spindle by hand - if it squeaks there may be a problem with the motor bearing. These are not usually serviceable and will need replacing.
  12. With some turntables the belt runs through some little guide wheels between the pulleys on the motor and the turntable drive spindle. These may need lubricating with a little VERY light oil. Sewing machine oil is perfect for this. Only use a tiny drop applied to the axle of the guide wheels with a very fine paint brush. Don't use to much or use anything in a spray can as it might get on the surface of the pulley wheels where it will contaminate the drive belt and cause it to slip.
Jan 30, 2011 | Crosley Cr6005a Turntable
I have a brand-new ITUIT-201 USB turntable with a wobbly platter (slight wobble at lower speeds, and very noticable at higher speeds). This causes the record to spin unevenly, and the needle slides...
Sometimes you can push down on the platter high side to bend it gently to get it to turn level. Being brand new, you can also return the unit for repair or replacement at no cost. The cost of these things does not justify putting up with defects like this. Good luck!
Dec 30, 2010 | Garden
Technics deck has power but stopped rotating
If you're lucky, this can just be a dirty/corroded speed control. Try removing the platter and you should see 2 holes lower center of the indented section. In those holes should be the coarse speed controls. These really set the range of the fine speed controls we play with on the outside. Use a good commercial contact cleaner and spray these babys. Gently move them a bit counter clockwise and clockwise, spray again, then return to about where they started.
If that doesn't help, you either have a motor issue or the controller board has a problem - no easy fix there.
Oct 23, 2010 | Technics SL-1210 Turntable
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Apr 07, 2009 | JVC AL A158BK Turntable
Cdj800 jog wheel stops working after 45mins
The drive motor on this unit is probably about to die, or the contact pad underneath the platter is damaged. In either case, you'll have to take it to a qualified service technician for diagnosis and repair.
- Optic
Digital Analog Therapy
www.repairny.com
www.1200s.com
Oct 05, 2008 | Pioneer CDJ-800 Turntable
CDJ 800 JOG WHEEL IS not working
sounds like the jogwheel sensor,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
May 06, 2008 | Pioneer CDJ-800 Turntable
Problem with Auto Return on Thorens Turntable TD 147
Hi, contact me direct and I will send you the service manual. John. styluscity@gmail.com
May 05, 2008 | Thorens TD-190 Turntable
Televison & Video Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
