Question about Brainydeal Elm327 Usb Auto Car Diagnostic Code Reader Scanner - Read Trouble Codes And Check Engine Lights Blue
How do you read codes through the check engine light?
    Genius:
  • 1,198 Answers
The code reader should have an owner's manual. It should have explanations of what the number of blinks mean. Codes are read from a wire connector.l
Posted on Nov 29, 2013
How reset check engine light
The easiest way to reset a check engine light on almost any modern car is to disconnect the battery wait five minutes and connect it back up. This will not tell you why the check engine light came on. For that you need a ODBII scanner, but if the issue was a gas cap left off and you have fixed that, then check engine the light should go off. I have found that many auto parts stores will read your car's ODBII codes for free.
Jun 30, 2014 | 1990 Mazda MX-5
How to reset engine lite in dash
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help links provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
Check Engine Light ON?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
Intermittent Check Engine Light?
http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
WHY Check Engine Light On car?
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Check Engine Light, VSC light and Traction Control Light ON?
http://whoisbyme.blogspot.com/2012/06/check-engine-lightvsc-light-and.html
Check engine light flashing?
http://technoanswers.blogspot.in/2012/02/check-engine-light-flashing.html
Service engine soon Light Turned OFF after Jump Start?
http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
After replacing throttle body the Check engine light starts blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
2005 Chevy Impala: Service Vehicle Soon Warning Light?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
Malfunction Indicator Light ON
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
Check power-train message with orange engine light came on?
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Vehicle smog test failed Due to NO MIL/check engine light?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These details will help.
Thanks.
Nov 28, 2012 | 1999 Acura CL
Check engine light on
Hi
When any vehicle engine light comes on it generates a code, that code is read by a diagnostic tool that reads identifies and displays the code(s), to indicate the problem the senors have detected.
Codes can be reset to recheck if the fault is genuine or not, but without the tool its difficult to determine the cause of the engine light appearing.
Read the manufacturers suggestions or call a garage for a diagnostic quote.
cheers
Oct 27, 2012 | 2005 Toyota Corolla
How to read check engine light codes
go to O-Reilly's Auto Parts and ask for them to read the check engine codes for you.
Sep 03, 2012 | Cars & Trucks
Why check engine bulb indicates
There is error code stored in your cars computer.It has to be scanned to retrieve the codes stored in it.I suggest you to click the help links shown below :----Check Engine Light On car? http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
--------------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
------------After replacing throttle body the Check engine light starts blinking? http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
-----------How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
-------------Check engine light with codes P2195 and P2197? http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
------------Car jerks while going uphill and Check engine light is ON? http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
-----------Vehicle smog test failed Due to NO MIL/check engine light? http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
-----------This will help.Thanks.
Feb 07, 2012 | Cars & Trucks
Check engine light vsc light and trac off light
VSC and TRAC lights will come on any time the check engine light does to reduce engine load. As such these lights being on may have nothing to do with the why the check engine light came on.
If the check engine light is on, a trouble code(s) has been stored in the computer that points to the problem area. The dealer should have read this code(s) to come up with what was wrong. Did the dealer give you a sheet with the trouble code number on it?
The engine may have variable valve timing, if it is not working the engine will revert back to a fail safe condition so that no damage will occur. But it will not be running a peak performance. Or it could be something with the engine timing system.
If you want to do your own checking, start calling autoparts stores to see if one will read the trouble codes for free, it is an easy job. AutoZone will read codes for free.
Hope this help.
Mar 28, 2010 | 2008 Toyota Sienna
Check engine light on 1998 Z3 BMW
BMW engine light
Comes on if DME engine management system self diagnostic fault detected. Will stay on until codes are called up and memory erased.
With OBD read the code as follows. Turn on ignition key, press accelerator pedal to the floor five times within 5 seconds. The check engine light will remain on for 5 sec , blik off, come on for 2,5 sec, go off for 2,5 sec and fault code will begin to flash. If more than one fault exist 2nd fault code will be separated by 2,5 sec pause. after fault codes there will be a 0.5 sec flash and light will remain off. to read codes again do procedure again.
Canceling of codes. make sure fault code is present (short blink and light goes out for long period), depress throttle pedal for at least 10 sec. read fault codes again and check for code 1444 (no faults stored.)
Check also the following, fuel pump, oxygen sensor, fuel injectors, engine coolant temp sensor, idle speed control valve, mass airflow sensor and too many other things.
Jun 16, 2009 | 1998 BMW Z3 Roadster
Check engine light
BMW engine light
Apr 12, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
I have problem with code 1126 (toyota 4 runner 2001
Manufacturer Specific Codes
P1100
BARO Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1120 Accelerator Pedal Position Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1126 Magnetic Clutch Circuit
P1127 ETCS Actuator Power Source Circuit
P1128 Throttle Control Motor Lock
P1129 Electric Throttle Control System
P1130 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1133 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1135 Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1150 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 2)
P1153 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 2) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
P1200 Fuel Pump Relay Circuit
P1300 Igniter Circuit Malfunction - No. 1
P1305 Igniter Circuit Malfunction - No. 2
P1335 No Crankshaft Position Sensor Signal - Engine Running
P1349 VVT System
P1400 Sub-Throttle Position Sensor
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1411 EGR Valve Position Sensor Circuit Range/Performance - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1500 Starter Signal Circuit
P1510 Boost Pressure Control Circuit
P1511 Boost Pressure Low
P1512 Boost Pressure High
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit
P1600 ECM BATT Malfunction
P1605 Knock Control CPU
P1630 Traction Control System
P1633 ECM
P1652 Idle Air Control Valve Control Circuit
P1656 OCV Circuit
P1658 Wastegate Valve Control Circuit
P1661 EGR Circuit
P1662 EGR Bypass Valve Control Circuit
P1700 Vehicle Speed Sensor '2' Circuit Fault
P1705 Direct Clutch Speed Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
Back To Top Of Toyota Check Engine Light Codes Page
Mar 21, 2009 | 2002 Toyota 4Runner
Codes for 1995 Mitsubishi eclipse
Engine-light-help.com
P1100 Induction Control Motor Position Sensor Fault
P1101 Traction Control Vacuum Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1102 Traction Control Ventilation Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1103 Turbocharger Wastegate Actuator
P1104 Turbocharger Wastegate Solenoid
P1105 Fuel Pressure Solenoid
P1294 Target Idle Speed Not Reached
P1295 No 5 Volt Supply To TP Sensor
P1296 No 5 Volt Supply To MAP Sensor
P1297 No Charge In MAP From Start To Run
P1300 Ignition Timing Adjustment Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1390 Timing Belt Skipped One Tooth Or More
P1391 Intermittent Loss Of CMP Or CKP Sensor Signals - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1400 Manifold Differential Pressure Sensor Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1443 EVAP Purge Control Solenoid '2' Circuit Fault
P1486 EVAP Leak Monitor Pinched Hose Detected
P1487 High Speed Radiator Fan Control Relay Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1489 High Speed Condenser Fan Control Relay Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1490 Low Speed Fan Control Relay Fault
P1492 Battery Temperature Sensor High Voltage
P1494 EVAP Ventilation Switch Or Mechanical Fault
P1495 EVAP Ventilation Solenoid Circuit Fault
P1496 5 Volt Supply Output Too Low
P1500 Alternator FR Terminal Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1600 Serial Communication Link
P1696 PCM Failure EEPROM Write Denied
P1698 No CCD Messages From TCM
P1715 Pulse Generator Assembly
P1750 Solenoid Assembly
P1791 PCM ECT Level Signal To TCM Circuit Fault
P1899 P/N Position/Transaxle Range Switch Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1751 A/T Control Relay
P1791 Engine Coolant Temperature Level Input Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1795 Throttle Position Input Circuit To TCM - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
Mar 21, 2009 | 1995 Mitsubishi Eclipse
Brainydeal Elm327 Usb Auto Car Diagnostic Code Reader Scanner - Read Trouble Codes And Check Engine Lights Blue Logo
123 people viewed this question
Top Brainydeal Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Brainydeal Office Equipment and Supply Expert? Answer questions, earn points and help others
