Question about Sylvania 6419TE 19" TV
TEAC Television -CT-M809AV -no picture
We have lost the picture on our TV after my young daughter pressed a button ( ?AV - near the volume control ) accidentally.
We have a blue screen and volume on each channel but no picture.
I connected the DVD player to another TV and it works fine so the problem appears to be with a setting on the TV.
Is it possible to reset the TV to the orginal factory settings and if so how???
thanks in advance.
Sally.
I dont have mannual and look thru menu and find nothing on av settings, any other ideas
Posted on Aug 06, 2008
Press AV again to switch back to normal tv mode....lol
Posted on Dec 20, 2007
  • 93 Answers
Maybe it's something with NTSC/PAL settings, or SOURCE SELECT. Check troubleshooting in your manual.
Posted on Oct 11, 2007
SOURCE:
Hi, how do i change the input mode so i can play music from a device through the television using these inputs.. (model type Logik L29HE12)
press the source button on your remote and select av
its between the channel and volume buttons
or press source on the buttons on the top of the tv
select av
Apr 04, 2018 | Televison & Video
I need remote codes for vizio vbr231 blue ray player as well as a teac home theater receiver AG D9260
We don't have codes for the Vizion Blue-Ray player but I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 06, 2011 | DISH Network IR Remote Control
How to select av without remote control
try pressing plus and minus channel on the tv at the same time. works with my daughters tv
Nov 16, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Can not find AV mode
try nd get a universal remote which supports all television sets....
Sep 05, 2009 | Televison & Video
Panasonic T.V. "Picture Menu Lock Mode"
On my 27" you need to press action and the channel button at the same time to unlock. Hope that helps!
Jul 22, 2008 | Televison & Video
Adding a channel to TEAC television
Hi I had the same problem so I bought a cheap universal remote controller and tuned into this model.
Once it is done, press a number on the remote controller and you can start to tune manually.
I do not know about the solution for AV channel.
Feb 14, 2008 | Televison & Video
Hi there
Check your DVD or Video player manual for regional setting, you may simply be set to the wrong region. Some players have a regional button on the remote control.
Regional settings allow DVD's or Videos to be played on the same player by simply selecting the correct regional setting.
If you are on the wrong regional setting, your picture will most likely appear in black and white.
Jan 12, 2008 | Televison & Video
Switch from AV to regular TV viewing
You try pressing the AV button on the side, sequentially until it changes back to a Channel Number. It should cycle through AV1, AV2, RGB, etc
Oct 25, 2007 | Durabrand DWT2405 24" TV
Tuner and AV problem
TRY TUNER ASSEMBLY SOLDER JOINTS COULD BE DRY OR CRACKS GOOD LUCK
Nov 06, 2006 | Panasonic CT-20G13 20" TV
Sylvania 6419TE 19" TV Logo
318 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
