Question about Grilling
Can i use a rotisserie to bake sculpey 3 clay
I want to know if i can use the sshowtime pro professional rotisserie and bbq for baking clay. any help will be great.
  • 2,113 Answers
Lol You can try
Posted on Nov 29, 2013
Cancan I use a foil baking tray in the severin 220 rotisserie toaster oven
You should read the booklet which comes with Severin toaster oven. They can write everything which type foil we should use in oven.
Spit Roast Catering
Jan 25, 2014 | Severin to2015 toaster oven for 220 volts
Sculpey and firm sculpey tend to crumble even after kneeding
Found this on the Sculpey website- Hope it helps :)
"If your clay is just a little dry or firm, it may only require the addition of Sculpey Clay Softener to reconstitute it (about 6 - 8 drops per 4 oz clay or 2 - 4 drops per 2 oz clay).The Clay Softener will not restore clay once it has become very hard or after it has been baked. If the clay is already crumbly, it has either had too much exposure to heat or old enough to have already undergone some chemical changes. At this stage, it cannot be reconstituted satisfactorily. Adding a pinch of Sculpey MoldMaker to clay that is a little dry or firm will also help reconstitute it."
http://www.sculpey.com/faq-new/209#
Sep 21, 2011 | Sculpey Crafts & Hobbies
I have some roseart modeling clay and I don't have the box it came in. Can it be dried in the oven and if so how do you do it?
You can dry it in the oven:
1. Preheat the oven to 300 degrees F. Remove all pots and pans from the oven. The clay gives off smoke that adheres to the pots and pans.
2. Place the modeling clay on a baking sheet and set it in the oven. Place it on the bottom shelf of the oven to give more room overhead. To prevent the clay from sticking to the baking sheet, place parchment paper on top of the baking sheet. Once you are finished, it is safe to use the baking sheet for cooking again, just wash it off with warm water and dish soap.
3. Wait at least 20 minutes and check on the clay. Touch the Rose Art clay to see if it is still soft. Larger, thicker clay pieces take longer to bake, so if the clay is still soft place it back in the oven
4. Check the clay every 10 minutes until the entire piece is hard. Once hard, remove it from the oven and allow it time to cool.
Hope it helps out!
May 08, 2011 | Roseart Toys
How do you make plates or bowls that are strong enough for everyday food use and you can use in the dishwasher? What material should you use (what kind of clay or other) and what is the process? Can I use...
You would want to use CERAMIC clay. The easiest way to make dishes is on a potter's wheel, but could be done with rolling pin and bowl / plate / cup to form. Roll clay anwhere from 1/4 to 1/2 inch thick, using flour or cornstarch to prevent sticking to work surface / tools / forms. Lay clay over form and trim off excess clay. As it will be very soft, you may want to leave it uncovered for a day or two so it can dry out and harden to near-leather hard.
You CAN use your oven to fire (bake), and for safe food / dishwasher use, after first firing, glaze with non-lead, non-toxic pottery glaze. *Careful not to get too thick as glaze WILL run during the second firing.
Your local Arts & Crafts / Pottery store should have all you need to make what you want, as well as DIY help on / with all aspects of pottery for even the greenest of beginners.
Mar 05, 2009 | Solar Southwest Pottery Light Switch Plate...
Lost instruction manual for Bravetti Model#TO285 toast/conv.oven
The same unit was marketed under the Euro-Pro name, with the same TO285 model number. The manual, as a PDF, as well some replacement parts are available at this link:
http://www.euro-pro.com/europro/default.aspx
Hope that helps.
Nov 30, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Need accessories for George Foreman Big rotisserie, baskets, baking tray, 4 tine spit forks, and baking rack.
I have a George Foreman Rotisserie Oven and in moving I have lost the drip tray (P/N21192) How can I get one?
Mar 25, 2008 | George Foreman GR82
Shark jet oven Euro ProX Manual
u can download manual i came across it by accident go to google put in shark jet oven and go where they sell it it has adown load manual at bottom of page
cheers Mary
Dec 06, 2007 | Euro-Pro K4245 Toaster Oven with...
Grilling Logo
46 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
